How to check rotated dimension is horizontal or vertical
tim11_manhhieu
Message 1 of 9
tim11_manhhieu
I have searched that there seems to be no direct method to determine whether the rotated dimension is horizontal or vertical, and if base on the text position and line dimension positions to calculate, there also seems to be no method to get the coordinates.
Replies (8)
Message 2 of 9
Ed__Jobe
This thread has the solution. Although it's in C#, you should be able to understand the principles.
Ed
How to post your code.
Message 3 of 9
tim11_manhhieu
There is no solution in that article.
The article mentions rotation, but VBA does not support it.
I have to ask the user to input the type of dimension.
Message 4 of 9
Ed__Jobe
That thread has two solutions as summarized in this post, and an AcadDimRotated object does have a Rotation property. Here's a sample to get you started.
Public Function IsHoriz(ent As AcadEntity) As String
    Select Case ent.ObjectName
        Case Is = "acDimRotated"
            Dim dr As AcadDimRotated
            Set dr = ent
            If dr.Rotation = 0 Or dr.Rotation = PI Then
                IsHoriz = "horizontal"
            ElseIf dr.Rotation = PI / 2 Or dr.Rotation = 3 * PI / 2 Then
                IsHoriz = "vertical"
            Else
                IsHoriz = "n/a"
        Case Is = "acDimAligned"
            'You can add the code for an aligned dimension.
        Case Else
            IsHoriz = "Error: Not a dimension object."
    End Select
End Function
Public Function PI() As Double
  PI = Atn(1) * 4
End Function
Ed
Message 5 of 9
tim11_manhhieu
thanks for your respond.
I tested, both case Horizontal or Vertical, dr.Rotation return zero 0.
Message 6 of 9
Ed__Jobe
It’s no wonder you get 0, you commented out all the code! Dr is an object that needs to be instantiated. When you comment out the code that sets it, it is null. So all its properties will be default values. Use the function as I wrote it and call it from your main method.
Sub Main
  Dim ent As AcadEntity
  Dim results As String
  ' code to select an entity
  results = IsHoriz(ent)
  Select Case = results
    Case = "horizontal"
      'Do something
    Case = "vertical"
      'Do something
  End Select
End Sub
Ed
Message 7 of 9
tim11_manhhieu
I modified code but it is not working.
Option Explicit
Sub Main()
    Dim ent As acadEntity
    Dim pt As Variant
    ThisDrawing.Utility.GetEntity ent, pt, "Pick dim: "
    Select Case results
    Case Is = "horizontal"
        Debug.Print "horizontal"
    Case Is = "vertical"
        Debug.Print "vertical"
    End Select
End Sub
Public Function IsHoriz(ent As acadEntity) As String
        Case Is = "AcDbRotatedDimension"
            Set dr = ent
            Else
                IsHoriz = "n/a"
        Case Else
    End Select
End Function
    PI = Atn(1) * 4
End Function
Message 8 of 9
Ed__Jobe
Although the AcadDimRotated object has a Rotation property, it seems to always be zero. So there's no way to figure out horizontal or vertical in ActiveX. You would need to use C# or possibly lisp.
Ed
Message 9 of 9
tim11_manhhieu
thank you.
