Where is the helix length ???
Message 1 of 8
Hey, I can´t believe there is no property for helix length !!!
Will I have to calculate it ???
Does anyone has the formulas or code for a general helix like autocad draws ???
Thanks !
Leonardo Roncetti
Replies (7)
Message 2 of 8
Just an idea only...
Get the helix volume and than divide it on section area
Fatty
~'J'~
Message 3 of 8
"TotalLength"
wrote in message news:[email protected]...
Thanks !
Leonardo Roncetti
Message 4 of 8
Hi Leonardo
Here is something similar on what you want
Give this a try
Dim objArr(0) As AcadEntity
Dim opath As Acad3DPolyline
Dim ocirc As AcadCircle
Dim oSol As Acad3DSolid
Dim RegVar As Variant
Dim oReg As AcadRegion
Dim rad As Double
Dim dia As Double
Dim pth As Double
Dim hgt As Double
Dim ang As Double
Dim pi As Double
Dim da As Double
Dim dz As Double
Dim dh As Double
Dim dr As Double
Dim num, iCnt, i, j As Integer
Dim cent(0 To 2) As Double
Dim varPt As Variant
Dim norm(0 To 2) As Variant
Dim stp(0 To 2) As Double
Dim strpt As String
Dim ptArr() As Double
Dim orig As Variant
Dim xax(0 To 2) As Double
Dim yax(0 To 2) As Double
Dim ucsName As String
Dim leng As Double
Dim curUCS As AcadUCS
Dim ucsMatx As Variant
Sub Helix()
rad = 100# ' outer radius of helix
dia = 25# ' wire diameter
pth = 25# 'pitch
num = 4 'number of rotation
hgt = pth * num
pi = Atn(1) * 4
dz = pth / 128 'number of division per rotation
dh = dz
da = pi / 64
dr = da
cent(0) = 0#: cent(1) = 0#: cent(2) = 0#:
iCnt = 0
On Error GoTo sayme
Do While dz <= hgt
varPt = ThisDrawing.Utility.PolarPoint(cent, da, rad)
ReDim Preserve ptArr(iCnt + 2)
ptArr(iCnt) = varPt(0)
ptArr(iCnt + 1) = varPt(1)
ptArr(iCnt + 2) = dz
dz = dz + dh
da = da + dr
iCnt = iCnt + 3
Loop
leng = Sqr((ptArr(3) ^ 2) + (ptArr(4) ^ 2) + (ptArr(5) ^ 2))
norm(0) = ptArr(3)
norm(1) = ptArr(4)
norm(2) = ptArr(5)
ThisDrawing.SendCommand "_SHADEMODE" & vbCr & "_2" & vbCr
Set opath = ThisDrawing.ModelSpace.Add3DPoly(ptArr)
strpt = Replace(CStr(norm(0)), ",", ".") & "," & _
Replace(CStr(norm(1)), ",", ".") & "," & _
Replace(CStr(norm(2)), ",", ".")
ThisDrawing.SendCommand "_-VIEW" & vbCr & "_RIGHT" & vbCr
ThisDrawing.SendCommand "_UCS" & vbCr & "_N" & vbCr & "_ZA" & vbCr & "0.0,0.0,0.0" & vbCr & strpt & vbCr & vbCr
stp(0) = ptArr(0): stp(1) = ptArr(1): stp(2) = ptArr(2)
Set ocirc = ThisDrawing.ModelSpace.AddCircle(stp, dia / 2)
Set objArr(0) = ocirc
RegVar = ThisDrawing.ModelSpace.AddRegion(objArr)
Set oReg = RegVar(0)
Set oSol = ThisDrawing.ModelSpace.AddExtrudedSolidAlongPath(oReg, opath)
ThisDrawing.SendCommand "_UCS" & vbCr & "_World" & vbCr
ThisDrawing.SendCommand "_SHADEMODE" & vbCr & "_G" & vbCr
sayme:
MsgBox Err.Description
End Sub
Fatty
~'J'~
Message 5 of 8
Sub HelixLength()
Dim retObj As Object
Dim retPnt As Variant
Dim Helix As AcadHelix
ThisDrawing.Utility.GetEntity retObj, retPnt, "Select helix: "
Set Helix = retObj
MsgBox Helix.TotalLength
End Sub
Message 6 of 8
Oh, my bad
You talking about Helix object as in 2007 version
I have A2005 only 😞
~'J'~
Message 7 of 8
That´s OK !!!
You code is very useful.
I have a kind of helix that has different quantity of segments per length, so Acad2007 does not handle it.
Thanks !!!
Message 8 of 8
Glad if this helps, but I don't tested this code
extensively, perhaps, might be any mistakes there
Happy computing,
Fatty
~'J'~
