ADO Unique values Field
Hi there all,
Does anyone know how to identify if a ADO recordset field has the property "no duplicates allowed"? (or which combination of properties)
I Use the reference activex data objects 2.8 library, with Autocad 2006/2007 and I read the recordset from a MS Access database.
Any help/advise?
A Caddie.
Caddie,
With ADO 2.8 you can check to see if your Attributes property exposes the adFldIsNullable enum. If so then you'll know the Field accepts null values.
G'Luck
Bob Coward
