visual basic in Autocad 2018 don't work
 Autocad  2018 for Student I've got recently isn't functioning as I expected.
Instruction like set lineObj=ThisDrawing.ModelSpace.Addline(startpt,endpt) causes run-time error '5': "invalid procedure  call or argument".
Help on this error is saying that an attempt is made to call a procedure that isn't valid on the current platform.
What platform is  that?
Beside  object oriented programming also opening  immidiate window is absolutely impossible, so debugging  output is missing, only write #(filenum) is working.
Miklavz
norman.yuan
If you pasted your code using the toolbar button "</>", it would have made it easier for other to read it without having to open the attached text file in a modal view.
Anyway, the points you declared in the code should be Double array, or Variant
Dim insertionpt(0 To 2) As Integer
Dim trta As AcadLine
Dim startpt(0 To 2) As Integer
Dim endpt(0 To 2) As Integer
should be
Dim insertionpt(0 To 2) As Double
Dim startpt(0 To 2) As As Double
Dim endpt(0 To 2) As As Double
Norman Yuan
Drive CAD With Code
lena.talkhina
Hello @Anonymous  !
Great to see you here on Visual Basic Customization Forum.
Did you find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. 🙂
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
Yes,  VBA is working now because all declared coordinates are double arrays not integer arrays
Thanks to Norman  and Lena.
