Picking a block from a drawing and copying into another
charley.rocha
Message 1 of 16
charley.rocha
Hello everyone,
I'm stuck with something that I think should be quite simple: I have a drawing with multiple blocks in it. Based on some conditions (this part os O.K to me) the macro should pick one of the blocks, copy it and paste into another drawing.
I'm not experienced in Autocad VBA, but I'm used to Excel VBA, and thus, although I don't know to achieve want I want to do, it seems to be simple. However, looking around in this forum I found some very complicated solutions to similar questions and I thought: there must be a simpler way.
Can anyone help me out with this?
The seemingly straight-forward method Drawing.CopyObjects doesn't work for me. It throws the error: CopyObjects failed, with code -2145320837 (8021007b)
Sub CopyingBlock()
Dim myBlock As AcadBlockReference
Dim oEnt As AcadEntity
Dim newPoint(0 To 2) As Double
newPoint(0) = 0
newPoint(1) = 0
newPoint(2) = 0
Dim blockName As String
blockName = "Teste"
For Each oEnt In ThisDrawing.ModelSpace
    If TypeOf oEnt Is AcadBlockReference Then
        Set myBlock = oEnt
        If myBlock.Name = blockName Then
            Dim awCopy As AcadDocument
            Set awCopy = ThisDrawing
            Dim awPaste As AcadDocument
            Set awPaste = Application.Documents.Open("D:\Users\charley_r\Desktop\TesteFernandinhoPaste.dwg")
            awCopy.CopyObjects myBlock, awPaste.ModelSpace
Next oEnt
End Sub
Replies (15)
Message 2 of 16
norman.yuan
That is because you passed WRONG parameter type to the first argument of CopyObject() method: the argument expect an ARRAY of object, but you passes a SINGLE object of AcadBlockReference
The code should look like something below (whether you may have multiple BlockReferences to be copied or not):
Dim ent As AcadEntity
Dim blk As AcadBlockReference
Dim sourceObjs() As object
Dim i As Integer
Dim copyDwg As AcadDocument
Dim pasteDwg As AcadDocument
Set copyDwg=ThisDrawing
For Each ent In copyDwg.ModelSpace
  If TypeOf ent Is AcadBlockReference Then
    Set blk = ent
    '' Use EffectiveName would be safer, in case the block is dynamic one
    If UCase(blk.EffectiveName)="TESTE" Then
      Redim Preserve sourceObjs(i)
      Set sourceObjs(i)=blk
      i = i + 1
Next
'' Only do copying if at least a target block reference is found
If UBound(sourceObjs)>=0 Then
  '' Go to the other drawing/ or Open it
  Set pasteDwg = ....
  copyDwg.CopyObject sourceObjs, pasteDwg.ModelSpace
Norman Yuan
Drive CAD With Code
Message 3 of 16
charley.rocha
Thanks a lot for your response, but I tried your code out and got the very same error: "CopyObjects method failed".
In fact, if the problem was passing an object instead of an array of objects, I would expect a Type Mismatch error (I may be wrong here, just wondering).
Any guess on what could be the problem now?
Thanks again.
Message 4 of 16
norman.yuan
Well, you DEFINITELY need to pass CopyObjects() an array of object to be copied.
The cause of issue (after passing an array of objects!) very likely is because of opening the paste drawing. Since AutoCAD2015 an breaking change was introduced: switching active drawing (in your case, open the drawing for pasting) would cancel current command. This change would also cancel code execution in most, if not all, cases. So, you need to have the destination drawing per-opened before executing your copying code. Following code works OK with my Acad2018/2020, where I have 2 drawing opened, and one has a block "Teste", whoch is to be copied to another:
Option Explicit
Public Sub CopyTest()
    Dim sourceObjs() As Object
    Dim i As Integer
    Dim dwg As AcadDocument
    For Each dwg In Documents
        Select Case UCase(dwg.Name)
            Case "DRAWING1.DWG"
            Set copyDwg = dwg
            Case "DRAWING3.DWG"
            Set pasteDwg = dwg
        End Select
    Next
    If copyDwg Is Nothing Then
        MsgBox "Source drawing is not open!"
        Exit Sub
    If pasteDwg Is Nothing Then
        MsgBox "Destination drawing is not open!"
        Exit Sub
            Set blk = ent
            If UCase(blk.EffectiveName) = "TESTE" Then
                ReDim Preserve sourceObjs(i)
                Set sourceObjs(i) = blk
                i = i + 1
    Next
    If VarType(sourceObjs) <> vbEmpty And UBound(sourceObjs) >= 0 Then
        copyDwg.CopyObjects sourceObjs, pasteDwg.ModelSpace
End Sub
Notice that I have a bit code to make sure both source/destination drawings are currently open in AutoCAD. Because I use drawing name to identify them, so, which one is active drawing does not matter when the code execution begins.
If you do want to only open the destination drawing when the source objects are found in source drawing, you may try open the destination drawing in memory only as ObjectDBX document, so the code execution would not be break by active drawing switch.
Norman Yuan
Drive CAD With Code
Message 5 of 16
charley.rocha
My deepest thanks mate! That code worked perfectly.
However, I wonder if opening the drawing in a separate method ou something could be a workaround for this.
You know, I'm just starting an automation project and the code I posted is the very beginning of things. When I'm finished, the user would click a button in an Excel spreadsheet, which will contain all the parameters and logic needed to determine which block to copy/paste.
I'll make a test telling Excel to open the drawings, and then calling the Autocad macro you provided to see if it works. In the mean time, feel free to share any thoughts on this, since I don't want the user to have the source and destination drawings open in front of him by the time the macro starts.
Anyways, you were of big help and your code is surely a breakthrough for my project. Thanks.
Message 6 of 16
norman.yuan
Well, if you start the process from external app (Excel VBA), you can certainly have both source and destination drawing open in AutoCAD first. I'd imagine the steps would be:
1. User runs Excel macro, which get an existing runing AutoCAD session, or create one (using GetObject()/CreateObjeect());
2. VBA code in Excel opens source drawing, and destination drawing(s) in AutoCAD;
3. VBA Code in Excel load the AutoCAD VBA project and then run the AutoCAD VBA macro to actually do the copying and saving the change to destination drawing(s);
Technically, you can do the copying all with VBA code in Excel, so that you have only one place to manage the code. However, that would slow down the execution significantly; I'd prefer the drawing processing work (copying) run inside AutoCAD as AutoCAD VBA macro.
I am also not fond of having to run 2 apps (Excel and AutoCAD) for such a simple work. I'd prefer do all in AutoCAD VBA. That is, you just need to read data from Excel sheet (if the data is stored as CSV file, the VBA code to read it would be a lot simpler, and running Excel app to reach the data is completely not needed).
Norman Yuan
Drive CAD With Code
Message 7 of 16
charley.rocha
Yeah, at this point my Autocad macro does the exact three steps you pointed out 😃
I get your concern about using two different applications, but in my case the user must have Excel open to input the required information to determine which block to copy from a template drawing to the final one, hence the button on the Excel spreadsheet. In my opinion, it would make little sense to have the user open Excel, input the data, close Excel, open Autocad and then run the macro...
Nevertheless, I appreciate your help so far and hope to be able to count on you again in future questions 😃
Best regards from Brazil.
Message 8 of 16
charley.rocha
@norman.yuan
Sorry for bothering you with this matter again, but I've been working with this project as I told you previously, and now I'm starting to write the real code. Almost everything is working fine: I'm able to open a template drawing, copy the correct block and place it on the final drawing. After that I can even move the block to its correct location. However, I just realized that I need to explode the blocks after pasting them. I tried
destObjs(0).Move blk.InsertionPoint, newPoint
destObjs(0).Explode
with no success. The blocks remain as blocks.
Do you have any idea of what could possibly be going on here?
Message 9 of 16
grobnik
@charley.rocha
Hi, could you try to apply to your code what generically below indicated:
Set explodedObjects = blockRefObj.Explode
I'm not sure, because I never tried this functionality
Let us know.
Message 10 of 16
charley.rocha
@grobnik Thanks for answering.
I tried to apply your suggestion but I'm not sure what type of variable should the explodedObjs be. I tried Variant, but got a Type Mismatch error. Tried an array of objects too, but got a "Can't assign to array" error.
Message 11 of 16
grobnik
@charley.rocha
Hi, probably should be a simple "object" because you are exploding a block, so should be no more a block, and in this case cannot be declared as "block" or "block reference".
Otherwise try to not declare (be careful if you settled before in your code Option Explicit).
As I wrote I'm not sure about the code, but should work because it's a simply block explode functionality, the main issue it's how to point to block to explode.
I'm sorry for poor support.
Bye
Message 12 of 16
Ed__Jobe
Here's the Help topic for the Explode method. As shown, the return object needs to be a variant. If you tried Variant, It should be working. Show your code so we can see what went wrong.
Ed
How to post your code.
Message 13 of 16
norman.yuan
@charley.rocha wrote:
@norman.yuan
destObjs(0).Explode
Your code (destObjs(0).Explode) should work, and I bet it must have worked and you just did not noticed:
AcadBlockReference.Explode() method works a bit differently from command "EXPLODE" - besides generate all the entities in the block definition in the same space as the block reference by "exploding it", the original block reference REMAINS UNCHANGED. It is up to you as programmer to decide you want to delete or not. The command "EXPLODE" combines the 2 steps in one (i.e. the block reference is removed after exploding API call).
You can verify it after AcadBlockReference.Explode() call without deleing the original block rerference: in AutoCAD editor, you should find all the block component entities and the block reference itself.
Norman Yuan
Drive CAD With Code
Message 14 of 16
charley.rocha
@norman.yuan @Ed__Jobe @grobnik
Looks like there was some bug in my autocad. After one more frustrated run of my macro, I decided to manually delete the blocks from the final drawing, and then purge them. Saved the document and tried again. As @norman.yuan predicted, all the blocks were duplicated on top of their exploded counterparts. Then I just added
destObjs(0).delete
and all I got were the exploded entities.
Thank your all for your good will.
Message 15 of 16
Ed__Jobe
Yes, you would only need to set explodedObjs if you planned to do something with them after exploding.
Ed
Message 16 of 16
charley.rocha
Hi again folks,
In case you feel like lending me a hand again, I did manage to copy all the blocks and assembly my desired drawing. Right now I'm at ~95% of what I want to achieve and I'm struggling with this, that I created a new topic for because it's another issue:
https://forums.autodesk.com/t5/visual-basic-customization/rotate-a-line-and-update-angular-dimension...
