VBA
VBA
VBA
Will a VBA script created in version 2010 be able to be loaded and run in versions 2015, 2016 without the user downloading the VBA module?
Alfred.NESWADBA
>> Will a VBA script [...]
Do you really mean "script" then it's not VBA.
If you wrote about VBA (stored as DVB-file) then you
  • need the VBA-Enabler to be installed
  • might need to adapt some code as AutoCAD 2015/2016 use not VBA7.1 (newer release) and in case of 64bit you might need top do some modifications.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
