INTERNAL ERROR!dbinsert.cpp@1309eLockViolation
a.a.w.degraaf
Message 1 of 13
a.a.w.degraaf
This error occurs
When this VB routine runs for de second time.
The first time it runs ok.
punt1 = ThisDrawing.Utility.GetPoint(, vbCr & "Geef het hart van de deuvel aan: ")
Hoek1 = ThisDrawing.Utility.GetAngle(punt1, vbCr & "Geef de richting van de Lijmnaad aan: ")
Set Deuvel_VBAZ = ThisDrawing.ModelSpace.InsertBlock(punt1, Deuvel_VBAZ_block, HschermD, HschermL, 1, Hoek1)
error report CER_113223800
how do i solf this problem
Accepted solutions (4)
Replies (12)
Message 2 of 13
Alfred.NESWADBA
are you running VB.NET or VBA?
From what source do you call that insert-module?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 13
a.a.w.degraaf
Thank you for the replay,
The routine runs by Microsoft VBA
Message 4 of 13
Alfred.NESWADBA
well, then you should not need to lock anything (that is only necessary when you would work with managed/dotNET and not based on COM).
In that case I would first look about other applications/plugins that run on top of your AutoCAD and to make sure you have the newest service pack for your AutoCAD installed.
- alfred -
Alfred NESWADBA
Message 5 of 13
a.a.w.degraaf
Thank you for jour suggetions.
The sp2 is all ready installed.
I will examen the applications/plugins.
-Bert
Message 6 of 13
Alfred.NESWADBA
Parallel to that you can try to make one small sample VBA, that just does the insertion ... in another module than your app, just to see if you have a generall error while inserting by VBA or if it's depending on the file you try to insert (try another drawing) just to make some steps to isolate the issue.
- alfred -
Alfred NESWADBA
Message 7 of 13
a.a.w.degraaf
Yes, thank you.
I have several of these routines and the the effect is the same.
The first time it runs perfect. The second time , the sam routine with that or any other block to insert, it crashes.
That makes me desperate.
By the way, i'm from Holland, excuses for the terrible english.
Message 8 of 13
Alfred.NESWADBA
Can you reproduce that in a separate DVB project?
If yes, then upload this project plus the drawings/blocks you are using.
- alfred -
Alfred NESWADBA
Message 9 of 13
Bonjour,
For me, the same error, some time the macro "inserer_bloc_accessoire1" works, some time i have an error.
So i work with "inserer_bloc_accessoire2 and no error.
My dvb and the 2 dwg are attached
Bernard
France
Message 10 of 13
FRFR1426
It looks like that this error happens when you call the InsertBlock method several times with the same file name. If you use the path only for the first time, then only the block name, it works as expected:
Dim blockFullPath as String
blockFullPath = "C:\Temp\MyBlock.dwg"
Dim blockName as String blockName = "MyBlock"
' Check if the block exists Dim exist as Boolean exist = False For i = 0 To ThisDrawing.Blocks.Count - 1 If ThisDrawing.Blocks.Item(i).Name = BlockName Then exist = True Exit For End If Next i
' Use the full path if block not exists or the block name if it exists
ThisDrawing.ModelSpace.InsertBlock(point, IIf(exist, blockName, blockFullPath), 1, 1, 1, 0)
Maxence DELANNOY
Manager
Add-ins development for Autodesk software products
http://wiip.fr
Message 11 of 13
a.a.w.degraaf
Dear sir,
It is a long time ago that i reply, thats becaurse i thouth tha an previously message you had achieved.
But the solution was "ThisDrawing.ActiveSpace = acModelSpace"
I fond it on internet an happily works.
Thanks for the support.
Message 12 of 13
a.a.w.degraaf
I fond the sollution here
Before the block is inserted place these syntax: ThisDrawing.ActiveSpace = acModelSpace
Place_drawing:
    Set Place_Block = ThisDrawing.ModelSpace.InsertBlock(Inv_Point, An_Block, 1, 1, 1, (angle1 - 1.5708))
Unload HoofdScherm
Exit Sub
Message 13 of 13
Alfred.NESWADBA
thank you for your feedback (for future readers) 😉
May I assume that within your code after the first look (when your code worked) and before the second look (when your code came up with the crash) you have changed the .ActiveSpace property? Otherwise I would not really understand the need for it.
- alfred -
Alfred NESWADBA
