VBA Not performing in autocad 2016
katlyn.dgrella
Message 1 of 18
katlyn.dgrella
I run a simple copy/paste/pasteordered text program on 2015 autocad that works wonderful.  I have tried to apply this same VBA to my 2016 Autocad and the macro loads with no issued but does not perform within the drawing.  Is there a setting of modification that needs to be made to allow this to function in the 2016 autocad?
attached is the code
Replies (17)
Message 2 of 18
Ed__Jobe
Welcome to the VBA forum. First, please don't attach code in a separate text file. Just insert it into the post using the code tags. On the editor menu, the button looks like </>. A popup appears where you can paste your code.
Two things to note.
1. When VBA loads your dvb, it compiles it to the latest version. So you won't be able to use the same dvb for 2015 and 2016.
2. In the VBAIDE, go to Tools>References and make sure that there are no references prefixed with "MISSING:". You may need to manually reference the 2016 type library.
Ed
How to post your code.
Message 3 of 18
katlyn.dgrella
Ok thank you.  How can I use the code written on the newer version of Autocad?
Message 4 of 18
Ed__Jobe
You just need to have 2 dvb's, with different file names. One for each version. Then for the 2016 dvb, make sure you follow step 2 in my previous post.
Ed
Message 5 of 18
katlyn.dgrella
there is no missing references and it is still not functioning correctly
Message 6 of 18
Ed__Jobe
Do you get any errors? Can you provide more information for troubleshooting?
Ed
Message 7 of 18
grobnik
Hi @katlyn.dgrella are you abke to run the procedure step by step, if there are error tappino like as on error resume next please make a commento forva whyle in order to understand the point where is hanghing
Message 8 of 18
katlyn.dgrella
Here is the DVB.
I have copied the file and renamed it to upload to the 2016 version and checked the missing reference library.  I have a custom toolbar button that references the different functions "Copy text"/"Paste text"/"Paste Text Ordered"
When I used the toolbar buttons my command reads the macro name and -vbarun but nothing happens
'AutoCAD VBA Macros
'Last Updated: 6/29/2005
Option Explicit
Public Sub PasteText()
'Pastes lines of text from the clipboard to text objects in AutoCAD
    On Error GoTo ExitSub
    Dim objText As Object, SelSet As AcadSelectionSet
    'Get the selected AutoCAD objects
    Set SelSet = AutoCAD.ActiveDocument.ActiveSelectionSet
    Dim iIndex As Integer, strText() As String
    Dim strNew As String, strClipboard As String
    Dim iTextIndex As Integer
    'Copy the contents off the clipboard
    strClipboard = modClipboard.GetText()
    If strClipboard = "" Then Exit Sub
    'Parse the contents into lines
    strText = Split(strClipboard, vbCrLf)
    iTextIndex = 0
    For iIndex = 0 To SelSet.Count - 1
        Set objText = SelSet.Item(iIndex)
        If iTextIndex > UBound(strText) Then Exit Sub
        'Determine if the selected item is text, and update it if it is
        If TypeOf objText Is AcadText Or TypeOf objText Is AcadMText Then
            strNew = strText(iTextIndex)
            objText.TextString = strNew
            iTextIndex = iTextIndex + 1
    Next iIndex
ExitSub:
End Sub
Public Sub CopyText()
'Copies multiple text objects from AutoCAD to the clipboard
    Dim strCopy As String, strClipboard As String
    Dim aText() As String
    iTextIndex = 0
    'Don't run without selected objects
    If SelSet.Count = 0 Then Exit Sub
        'Determine if the selected item is text, and put text in array if it is
            strCopy = objText.TextString
            ReDim Preserve aText(0 To iTextIndex)
            aText(iTextIndex) = strCopy
    Next iIndex
    Dim strBuffer As String
    strBuffer = ""
    'Now populate the clipboard with data from the array
    For iIndex = 0 To UBound(aText)
        strBuffer = strBuffer & aText(iIndex)
        'Add a carriage return for all but the last item
        If iIndex < UBound(aText) Then
            strBuffer = strBuffer & vbCrLf
    Next iIndex
    'Update the clipboard
    Call modClipboard.SetText(strBuffer)
ExitSub:
End Sub
Public Sub PasteTextOrdered()
'Pastes text from the clipboard in the order specified by the user
    'Get the active document
    Dim objDoc As AcadDocument, SelSet As AcadSelectionSet
    Set objDoc = AutoCAD.ActiveDocument
    'Get the selected objects
    Set SelSet = objDoc.ActiveSelectionSet
    Dim strPrompt As String, strInput As String
    Dim intCoord As Integer
    'Prompt the user for vertical or horizontal ordering
    strPrompt = vbCrLf & vbCrLf & "Specify [Vertical/Horizontal]: "
    strInput = objDoc.Utility.GetString(1, strPrompt)
    'Determine the user's input and update the coordinate type and next prompt
    If InStr(Mid("horizontal", 1, Len(strInput)), LCase(strInput)) <> 0 Then
        intCoord = 0
        strPrompt = vbCrLf & vbCrLf & "Specify [Left/Right]: "
    Else
        intCoord = 1
        strPrompt = vbCrLf & vbCrLf & "Specify [Top/Bottom]: "
    'Get user input about top-bottom left-right ordering
    Dim blnTopRight As Boolean
    'Set variables based on user input
    If intCoord = 1 Then
        If InStr(Mid("bottom", 1, Len(strInput)), LCase(strInput)) <> 0 Then
            blnTopRight = False
        Else
            blnTopRight = True
    Else
         If InStr(Mid("right", 1, Len(strInput)), LCase(strInput)) <> 0 Then
            blnTopRight = True
        Else
            blnTopRight = False
    Dim aTextObjects() As Object, objText As Object
    'Sort the objects based on user settings
    aTextObjects = SortTextObjects(SelSet, intCoord, blnTopRight)
    For iIndex = 0 To UBound(aTextObjects)
        Set objText = aTextObjects(iIndex)
        If iIndex > UBound(strText) Then Exit Sub
        strNew = strText(iIndex)
    Next iIndex
ExitSub:
End Sub
Message 9 of 18
Ed__Jobe
Can you run it using the VBARUN command? As @grobnik mentioned, you can set a breakpoint in the CopyText sub and step through each line to see what line the command fails on. Note that the use of On Error GoTo :ExitSub may be masking a new error that you didn't plan for. Try commenting out that line and debugging again.
Ed
Message 10 of 18
grobnik
Hi @katlyn.dgrella place ' before
And press F9 (function key) on next code row and run the first procedure. When the procedure stop on the red line highlihted goto step by step with F8 until error msg will appeal, do nothing and press debug on error message window.
Message 11 of 18
katlyn.dgrella
ok  I then get an error "mismatch" on
Message 12 of 18
katlyn.dgrella
this is modClipboard
'Function calls to access Windows clipboard
Option Explicit
Private Declare PtrSafe Function IsClipboardFormatAvailable _
    Lib "user32" _
    (ByVal uFormat As Long) As Long
Private Declare PtrSafe Function OpenClipboard _
    Lib "user32" _
    (ByVal Hwnd As Long) As Long
Private Declare PtrSafe Function GetClipboardData _
    Lib "user32" _
Private Declare PtrSafe Function GlobalSize _
    Lib "kernel32" _
    (ByVal hMem As Long) As Long
Private Declare PtrSafe Function GlobalLock _
    Lib "kernel32" _
Private Declare PtrSafe Sub MoveMemory _
    Lib "kernel32" Alias "RtlMoveMemory" _
    (ByVal strDest As Any, _
    ByVal lpSource As Any, _
    ByVal Length As Long)
Private Declare PtrSafe Function GlobalUnlock _
    Lib "kernel32" _
Private Declare PtrSafe Function CloseClipboard _
    Lib "user32" () As Long
Private Declare PtrSafe Function GlobalAlloc _
    Lib "kernel32" _
    (ByVal uFlags As Long, ByVal dwBytes As Long) As Long
Private Declare PtrSafe Function EmptyClipboard _
Private Declare PtrSafe Function SetClipboardData _
    Lib "user32" _
    (ByVal uFormat As Long, ByVal hData As Long) As Long
Private Declare PtrSafe Function GlobalFree _
    Lib "kernel32" _
Private Const GMEM_MOVABLE = &H2&
Private Const GMEM_DDESHARE = &H2000&
Private Const CF_TEXT = 1
'Error return codes from Clipboard2Text
Private Const CLIPBOARDFORMATNOTAVAILABLE = 1
Private Const CANNOTOPENCLIPBOARD = 2
Private Const CANNOTGETCLIPBOARDDATA = 3
Private Const CANNOTGLOBALLOCK = 4
Private Const CANNOTCLOSECLIPBOARD = 5
Private Const CANNOTGLOBALALLOC = 6
Private Const CANNOTEMPTYCLIPBOARD = 7
Private Const CANNOTSETCLIPBOARDDATA = 8
Private Const CANNOTGLOBALFREE = 9
Function SetText(strText As String) As Variant
    Dim varRet As Variant
    Dim fSetClipboardData As Boolean
    Dim hMemory As Long
    Dim lpMemory As Long
    Dim lngSize As Long
    varRet = False
    fSetClipboardData = False
    ' Get the length, including one extra for a CHR$(0)
    ' at the end.
    lngSize = Len(strText) + 1
    hMemory = GlobalAlloc(GMEM_MOVABLE Or _
        GMEM_DDESHARE, lngSize)
    If Not CBool(hMemory) Then
        varRet = CVErr(CANNOTGLOBALALLOC)
        GoTo SetTextDone
    ' Lock the object into memory
    lpMemory = GlobalLock(hMemory)
    If Not CBool(lpMemory) Then
        varRet = CVErr(CANNOTGLOBALLOCK)
        GoTo SetTextGlobalFree
    ' Move the string into the memory we locked
    Call MoveMemory(lpMemory, strText, lngSize)
    ' Don't send clipboard locked memory.
    Call GlobalUnlock(hMemory)
    ' Open the clipboard
    If Not CBool(OpenClipboard(0&)) Then
        varRet = CVErr(CANNOTOPENCLIPBOARD)
    ' Remove the current contents of the clipboard
    If Not CBool(EmptyClipboard()) Then
        varRet = CVErr(CANNOTEMPTYCLIPBOARD)
        GoTo SetTextCloseClipboard
    ' Add our string to the clipboard as text
    If Not CBool(SetClipboardData(CF_TEXT, _
        hMemory)) Then
        varRet = CVErr(CANNOTSETCLIPBOARDDATA)
    Else
        fSetClipboardData = True
SetTextCloseClipboard:
    ' Close the clipboard
    If Not CBool(CloseClipboard()) Then
        varRet = CVErr(CANNOTCLOSECLIPBOARD)
SetTextGlobalFree:
    If Not fSetClipboardData Then
        'If we have set the clipboard data, we no longer own
        ' the object--Windows does, so don't free it.
        If CBool(GlobalFree(hMemory)) Then
            varRet = CVErr(CANNOTGLOBALFREE)
SetTextDone:
    SetText = varRet
End Function
Public Function GetText() As Variant
    Dim hMemory As Long
    Dim strText As String
    Dim lngSize As Long
    varRet = ""
    ' Is there text on the clipboard? If not, error out.
    If Not CBool(IsClipboardFormatAvailable _
        (CF_TEXT)) Then
        varRet = CVErr(CLIPBOARDFORMATNOTAVAILABLE)
        GoTo GetTextDone
        GoTo GetTextDone
    ' Get the handle to the clipboard data
    hMemory = GetClipboardData(CF_TEXT)
        varRet = CVErr(CANNOTGETCLIPBOARDDATA)
        GoTo GetTextCloseClipboard
    ' Find out how big it is and allocate enough space
    ' in a string
    lngSize = GlobalSize(hMemory)
    strText = Space$(lngSize)
    ' Lock the handle so we can use it
    ' Move the information from the clipboard memory
    ' into our string
    Call MoveMemory(strText, lpMemory, lngSize)
    ' Truncate it at the first Null character because
    ' the value reported by lngSize is erroneously large
    strText = Left$(strText, InStr(1, strText, Chr$(0)) - 1)
    ' Free the lock
GetTextCloseClipboard:
GetTextDone:
    If Not IsError(varRet) Then
        GetText = strText
    Else
        GetText = varRet
End Function
Message 13 of 18
grobnik
Seems not so easy. Are you sure that there isn't another way to do what do need ? Why use clipboard ? I guess could you use a text file or something like as.
Message 14 of 18
Ed__Jobe
GetText is declared as a Variant. The windows function sets varRet, a variant. Without stepping through the code myself, I'm assuming that it is an array of strings. Dim strClipboard as a variant and pause on the line to examine its contents in the Locals window to see how you can process its contents.
Ed
Message 15 of 18
katlyn.dgrella
this tool was created before I was employed at this company. I am just trying to implement it on another work station. There is probably an easier solution out there.
Message 16 of 18
norman.yuan
So, your issue is not from VBA itself, but from Windows API calls, which are for 32bit CPU. Since I saw the code was last updated in year 2005 (when the AutoCAD VBA was 32 bit), but you claimed it worked with your AutoCAD 2015(?), so I can only assume your Acad2015 is also 32-bit version (thus its VBA is also 32 bit). I also assume that your Acad2016 is 64-bit, thus, the code stops work. You need to update the Windows API functions (those declares like "Private Declare PtrSafe Function ...". You can search the internet, you should be able to find plenty of links. One of ithem might be "ready-to-use" (I never used/tested it):
https://francescofoti.com/2013/12/share-the-clipboard-with-vba-and-the-windows-api/
HTH
Norman Yuan
Drive CAD With Code
Message 17 of 18
grobnik
Yes, copy the text in windows clipboard and paste on autocad dwg, later you
can apply style and so on.
If I remember well the result should be a mtext in dwg.
Message 18 of 18
katlyn.dgrella
Thank you all for your help.
A solution was found.  The code was simplified to use the DataObject variable to copy to the computers clipboard. then retrieving the text from clipboard.
Sub CopyTextToClipboard()
'PURPOSE: Copy a given text to the clipboard (using DataObject)
'SOURCE: www.TheSpreadsheetGuru.com
'NOTES: Must enable Forms Library: Checkmark Tools > References > Microsoft Forms 2.0 Object Library
Dim obj As New DataObject
Dim txt As String
'Put some text inside a string variable
  txt = "This was copied to the clipboard using VBA!"
'Make object's text equal above string variable
  obj.SetText txt
'Place DataObject's text into the Clipboard
  obj.PutInClipboard
'Notify User
  MsgBox "There is now text copied to your clipboard!", vbInformation
End Sub
Dim DataObj As New DataObject
    Dim S As String
    DataObj.GetFromClipboard
    S = DataObj.GetText
    Debug.Print S
