Reading a System Variable from an external drawing
nick.seman
nick.seman
Hello:
I have written some code that allows the user to select a project directory through which it finds all the DWG's in the directory structure and creates a report listing each drawing's name and the names of each drawing's xreferenced files along with their insert units.  I would also like to include the insunits value for each parent drawing however I am having difficulty getting that to work.
I cannot use the ThisDrawing.GetVariable("InsUnits") as I never have the parent drawing open or active.  I use  AXDBLib.AxDbDocument to set a variable as the document, then look for the blocks (isxref) inside of it.  That works but apparently the object does not support the GetVariable method.
I have also tried setting an object equal to the drawing's database however I am not finding that I can extract system variable information that way either.
I apologize as I am sure I am butchering the terminology here - I am not a programmer . . .
I appreciate any direction you may be able to provide.  In short - I would like to extract the value of a system variable from a drawing other than the currently open drawing.
Thanks;
Nick
nick.seman
OK - alternatively - is it impossible to extract a system variable value from a drawing that is not currently open ?
Thanks;
Nick
Ed__Jobe
I haven't tried getting a var from an axDbDocument, but I don't see why you can't. Instead of using ThisDrawing, use the axDbDocument object.
Ed
How to post your code.
Ed__Jobe
Just did a test to confirm and you can't get a variable using AxDb.
Ed
nick.seman
Hi Ed:
Thanks for checking this out and I apologize for not getting back to you after your first post.
I did try what you suggested and came to the same result that you did.
Thanks again,
Nick
