VBA - Not Installed
VBA - Not Installed
Leo_alhaj
Observer Observer
Message 1 of 11
VBA - Not Installed
Leo_alhaj
Observer
Observer
I keep getting this error every time I open my drawings, i have the latest c3d 2024 with 2024 VBA, please advise
Replies (10)
Message 2 of 11
Ed__Jobe
I would try uninstalling VBA and then reinstalling it.
Ed
How to post your code.
Message 3 of 11
Leo_alhaj
Observer
Observer
I tried that, also I tried to uninstall c3d and reinstall it, also didn't work. i tried few versions of c3d and it's the same for all 2021,2022,2023 and 2024.
Message 4 of 11
Ed__Jobe
If you right click on the installer exe and select Run As Administrator, does it work?
Ed
Message 5 of 11
Norman_Yuan
The answer would be obvious, but I ask anyway: you do know install AutoCAD/C3D does not install VBA automatically, don't you? It is up to you to downloaded separately and install it.
Norman Yuan
Drive CAD With Code
Message 6 of 11
Leo_alhaj
Observer
Observer
Tried both, @Ed__Jobe.
Yes i did download it separately @Norman_Yuan
Message 7 of 11
Ed__Jobe
Can you post a picture of the error message you get? Does it only happen when you load a dwg?
This is more of a tech support problem than a programming one. Do you realize that you can contact support?
Ed
Message 8 of 11
Leo_alhaj
Observer
Observer
not all drawings, but yeah if i open that dwging it gives me that error.
Message 9 of 11
Ed__Jobe
What happens if you type VBAMAN?
Ed
Message 10 of 11
Leo_alhaj
Observer
Observer
Message 11 of 11
Ed__Jobe
That proves that VBA is actually installed. You may be getting those errors if the dwg has a VBA project embedded in it. But you shouldn't be getting that message. If you open a dwg that produces the error, click on Continue with Current Command to see if the dwg will finish loading. Then run VBAMAN and see if the dwg has a project embedded in it.
Ed
