vba lockup
vba lockup
vba lockup
I have modified Autojournal (from autojournal.net, free source code
download) for my use. I simply changed it so that it did not have to track
time of use for each document but merely when a document was opened. I will
work on the time tracking if I can get this to work.
I used the following code with a sub of AcadStartup that merely initializes
the AcadApplication Events. Everything seems to work fine if I run the macro
"AcadStartup" at the command line after starting Acad 2000. Every following
document is logged in the Outlook Journal.
My problem is that when I put the line (command "-vbarun" "acadstartup") at
the end of acad2000.lsp or acad2000doc.lsp the module locks me up. Acad acts
as though there is a command in process but I cannot do anything. When I
type at the command prompt the curser moves over like text is being typed
but nothing appears on screen. I cannot escape out of the command not
execute and menu command. When I attempt to exit Acad I am told that a
command is in process and I need to exit the command before I can exit Acad.
I have to force Acad to exit by using the task manager.
Here's an even weirder twist. The code is set to skip any "Drawing*"
documents as I do not want any new documents logged, only saved documents so
when Acad is started with the (command "-vbarun" "acadstartup") in the
acad2000doc.lsp it will not
lock up until I open another document. So after initially starting Acad I
bring up the vba editor, toggle a breakpoint to follow the code and then
everything works just fine. No lockup! I am at a loss as to how to
troubleshoot this. Any Ideas?
Joel
joel@NSPM.harden-assoc.com
remove the NSPM. to email me directly
Public WithEvents ACADApp As AcadApplication ' Use with Application Event
Examples
''' using outlook - be sure to go to Tools > References
''' and add the Microsoft Outlook library to the project
Public oOutlookApp As Outlook.Application
Public oJournal As Outlook.JournalItem
''' declare a couple of variables for managing the journal
Private strFilename As String
Sub AcadStartup()
' This example intializes the public variable (ACADApp) which will be
used
' to intercept AcadApplication Events
' The VBA WithEvents statement makes it possible to intercept an generic
Object
' with the events associated with that object.
' Before you will be able to trigger any of the AcadApplication events,
' you will first need to run this procedure.
' We could get the application from the ThisDocument object, but that
would
' require having a drawing open, so we grab it from the system.
Set ACADApp = GetObject(, "AutoCAD.Application")
End Sub
Private Sub ACADApp_EndOpen(ByVal FileName As String)
''get documents name
strFilename = ThisDrawing.Name
'' exit if no document name
If strFilename = "" Then Exit Sub
'' exit if this is a new drawing
If strFilename Like "Drawing*" Then Exit Sub
'' start a new journal entry
StartJournal
End Sub
''' start journal - helper routine
Private Sub StartJournal()
'' get the outlook application
Set oOutlookApp = CreateObject("Outlook.Application")
'' create a new journal entry
Set oJournal = oOutlookApp.CreateItem(olJournalItem)
'' set the category, and start timing
With oJournal
.Subject = strFilename
.Type = "AutoCAD"
.Save
End With
End Sub
Can anyone explain this?
I took out the (command -vbarun... from acad2000.lsp and acad2000doc.lsp.
acad.dvb is in the support path and is loaded properly but won't run the
thisdrawing events unless I open the vba editor window. Once I open the
window then acad intercepts the thisdrawing events and the code works like
it is supposed to. Is the action of loading the VBA window doing something
other than showing me the code?
Joel
Yip I have exactly the same thing. I think I read if you issue a command of
the name "vba..." it initializes these events I haven't work out how but I
think you need to use s::startup to get around this
"Joel Zimmerman" wrote in message
news:16363F0D73F4668354D28ED92A2979F8@in.WebX.maYIadrTaRb...
will
initializes
macro
following
at
acts
Acad.
so
> Joel
Event
> Examples
> Sub AcadStartup()
> used
generic
> Object
events,
> would
> End Sub
> StartJournal
> End Sub
> With oJournal
> .Type = "AutoCAD"
> .Save
> End With
> End Sub
Have you loaded acadvba.arx prior to calling your routine?
"Mark Gardiner" wrote in message
news:8CDF18C8FF05CEA7B861845BD66C611F@in.WebX.maYIadrTaRb...
of
track
> will
> initializes
> macro
> following
> at
> acts
typed
> Acad.
documents
> so
I
then
> > Joel
> Event
> > Examples
> > Sub AcadStartup()
be
> > used
> generic
> > Object
> events,
that
> > would
> > End Sub
> > StartJournal
> > End Sub
> > With oJournal
> > .Type = "AutoCAD"
> > .Save
> > End With
> > End Sub
Thanks Richard that was just wanted
Mark
"Richard Binning" wrote in message
news:69F01310B43142528E2E9FCE1791AD3F@in.WebX.maYIadrTaRb...
> of
I
> track
> > will
> > initializes
> > macro
> > following
"acadstartup")
> > at
Acad
> > acts
I
> typed
> > Acad.
> documents
> > so
Acad
> I
> then
> > > Joel
> > Event
> > > Examples
> > > Sub AcadStartup()
> be
> > > used
> > generic
> > > Object
> > events,
> that
> > > would
> > > End Sub
> > > StartJournal
> > > End Sub
> > > With oJournal
> > > .Type = "AutoCAD"
> > > .Save
> > > End With
> > > End Sub
