How do I set a Block Reference to a known Block Name?
BlockName is the Block
oAcadApp is my AutoCad object
'Set the Block
Dim acoActiveBlock As AcadBlock
Set acoActiveBlock = oAcadApp.ActiveDocument.Blocks(BlockName)
'Set the Block Reference Object
Dim acoBlockRef As AcadBlockReference
Set acoBlockRef = acoActiveBlock
The above code keeps giving a type mismatch error. How do I set the block
reference to the know 'BlockName'
Chris
Three ways:
1) Have the user manually select an insert
2) Loop through every objectin the database looking for inserts
3) Use a filtered selection set to acquire the inserts.
Good judgment comes from experience.
Experience comes from bad judgment.
http://www.acadx.com
"Veign" wrote in message
news:0003A30E758FF35A654D28FCB1B7699E@in.WebX.maYIadrTaRb...
> 'Set the Block
> Chris
Block references can only be set from Inserts??
"Frank Oquendo" wrote in message
news:8F9C6BB8C22CDB9797D33929EE5F5F3B@in.WebX.maYIadrTaRb...
> Three ways:
> > 'Set the Block
block
> > Chris
I guess the questions is then. With a known block, already inserted into a
drawing, how do I change one of its attributes?..
> Three ways:
> > 'Set the Block
block
> > Chris
Yes, AcadblockReference = Insert.
news:F98297EC1D2D5ECFAB5E41C86BD4BFFE@in.WebX.maYIadrTaRb...
> > Three ways:
> > > 'Set the Block
> block
> > > Chris
Use the GetAttributes method. This will return a variant containing an array
AcadAttributeReferences. Use the TextString property to change the value.
news:35561CB525ED60BBC0CC69160A26675F@in.WebX.maYIadrTaRb...
a
