VBA is not identifying "ThisDrawing"
nitin.rathod3CW9S
nitin.rathod3CW9S
My VBA code is not identifying/compiling "ThisDrawing", May be I'm missing any reference or library?
below is the screenshot of the compile error it shows. I've also copied the sub in case anybody wants to help me.
'reference to "Autodesk SymBBAuto 4.0 Type Library".
Sub createPartReference()
Dim oAcApp As AcadApplication
Dim oAcUtil As AcadUtility
Set oAcApp = GetObject(, "AutoCAD.Application")
Set oAcUtil = oAcApp.ActiveDocument.Utility
Dim oAcDwg As AcadDocument
Set oAcDwg = oAcApp.ActiveDocument
'oAcApp
Dim pt As Variant
pt = oAcUtil.GetPoint(, "Location for ampartref: ")
pt = oAcUtil.TranslateCoordinates(pt, acUCS, acWorld, False)
Dim oPartref As McadPartReference
'Set oPartref = oAcDwg.ModelSpace.AddCustomObject("AcmPartRef")
Set oPartref = ThisDrawing.ModelSpace.AddCustomObject("AcmPartRef")
oPartref.Origin = pt
Dim oSymbb As McadSymbolBBMgr
Set oSymbb = ThisDrawing.Application.GetInterfaceObject("SymBBAuto.McadSymbolBBMgr")
'Set oSymbb = oAcDwg.Application.GetInterfaceObject("SymBBAuto.McadSymbolBBMgr")
Dim oBommgr As McadBOMMgr
Set oBommgr = oSymbb.bomMGR
Dim pdata(0 To 5, 0 To 1) As String
pdata(0, 0) = "DESCR": pdata(0, 1) = "My Description"
pdata(1, 0) = "STANDARD": pdata(1, 1) = "My Standard"
pdata(2, 0) = "MATERIAL": pdata(2, 1) = "My material"
pdata(3, 0) = "NOTE": pdata(3, 1) = "My note"
pdata(4, 0) = "VENDOR": pdata(4, 1) = "My vendor"
pdata(5, 0) = "NAME": pdata(5, 1) = "Comp1"
oBommgr.SetPartData oPartref, pdata
ThisDrawing.Application.Update
'oAcDwg.Application.Update
End Sub
Ed__Jobe
Apparently you are using Excel VBA or some other program. The objects AcadApplication and ThisDrawing are only created when you are working on VBA within AutoCAD. Otherwise you need to create your own variables. You can use ThisDrawing if you want, using
ThisDrawing As AcadDocument
ThisDrawing = Application.ActiveDocument
Don't forget that if you switch active documents, you need to update your variable since you're not working in AutoCAD's VBA.
In your code, instead of:
you should have used:
oAcApp.GetInterfaceObject
Ed
How to post your code.
nitin.rathod3CW9S
thanks for response.
Like you guessed, I'm using excel VBA.
If you scroll above, I've tried creating my own active document with name "oAcDwg" but then It changes the error message to "Type mismatch".
Ed__Jobe
I can't tell at which line the error occurs. When you are setting the document or the partref?
Ed
