VBA Create Arch from 3 points
jalal.mousa
jalal.mousa
Hi There,
i would like to create Arch from the last three points used to create closed polyline
so on Error i would like to use [Lastpoint/Ok/Resume/Delete/Arch]: ") Arch option and code will use last three points entered by use to create arch
see attached i would like to convert for example points 3 to 5 as Arch then continue tracing room
On Error Resume Next
For i = 0 To 2000 Step 3
Label1:
AktPt = MyDWG.Utility.GetPoint
ReDim Preserve points(i + 5) As Double
plineObj.Delete
points(i) = AktPt(0)
points(i + 1) = AktPt(1)
points(i + 2) = AktPt(2)
points(i + 3) = points(0)
points(i + 4) = points(1)
points(i + 5) = points(2)
Set plineObj = MyDWG.ModelSpace.AddPolyline(points)
'LastplineObj = MyDWG.ModelSpace.AddPolyline(points)
If Err Then
Err.Clear
returnString = MyDWG.Utility.GetKeyword(vbLf & "Enter a keyword [Lastpoint/Ok/Resume/Delete/Arch]: ")
Moderator edit: Put code in code window. Please use </>  button to add.
Ed__Jobe
The PLINE command already does this. You just have to choose the ARC option, and then there are options for creating an arc. Is there a reason you need to do this programmatically?
Ed
How to post your code.
jalal.mousa
yes i am using Excel to do drawing and program return Area automatically to Excel
Ed__Jobe
Ok, may I suggest, rather than retracing over existing lines and arcs, use them to create a region and then get Area property.
Ed
jalal.mousa
Hi Ed,
thanks for getting back to me
the reason i am doing tracing is that file i have is PDF and inserted to Autocad as an image or imported to from pdf file
as per screen shot below
in both cases it will be hard to achieve closed polyline or create regon
Ed__Jobe
Here is what help says:
VBA Reference for AddPolyline wrote:
Remarks
To create a polyline containing arcs, first create the straight polyline, and then set the bulge at specific vertices using the SetBulge method.
This method exists for backward compatibility only. Use the AddLightweightPolyline method to create polylines with an optimized format that saves memory and disk space.
The only option is to use the SetBulge method. See that topic for how to calculate the bulge factor.
I'm still a little curious how you are getting the point list if the pdf is just an image.
As a side note, you are referring to an "arc", not "arch".
Ed
