remove all formatting of MText
hari.ramalingam
hari.ramalingam
Hi all,
Is it possible to achieve remove all formatting of Mtext using VBA?.
WE got a lisp routine and its not working for certain dwgs whereas work for certain dwgs
thanks
Hari R.
Ed__Jobe
The best way is to use REGEX. Here's a sample I was playing with some time ago. You may need to fine tune it to fit your needs. Your project needs to reference "Microsoft VBScript Regular Expressions 5.5".
Sub RegexTestMtext()
    Dim rg As New RegExp
    Dim str As String
    With rg
        .Global = True
        .MultiLine = True
        .IgnoreCase = False
        .Pattern = "\\[A-Za-z0-9.\/\#\^]+;"
    End With
    str = "{\fArial|b0|i0|c0|p34;weight}"
    If rg.test(str) Then
        Debug.Print rg.Replace(str, "$1")
    Else
        Debug.Print "No Match"
End Sub
Ed
How to post your code.
