VBA connection ms.access vs AutoCAD (subscript out of range)
In the past i was allways use this vba file to make connection to ms.access database.
But on some reason it give me now connection error with "subscript out of range"
Private Sub Class_Initialize()
    On Error GoTo errInit
    Set adoConnection = New ADODB.Connection
    Set adoRC = New ADODB.Recordset
    With adoConnection
        .Open "Provider=Microsoft.JET.OLEDB.12.0;Data Source=" & "E:\TEST\Info64.accdb"
    End With
    On Error Resume Next
    ThisDrawing.SelectionSets("KADER").Delete
    Set objSSet = ThisDrawing.SelectionSets.Add("KADER")
    Exit Sub
errInit:
    MsgBox err.Description, vbCritical, "Ado Connection"
    Set adoConnection = Nothing
    Set adoRC = Nothing
    err.Raise err.Number, Me, err.Description
Ed__Jobe
Have you set a breakpoint and stepped through the code to see where the error is coming from?
Ed
How to post your code.
norman.yuan
You need to tell which OS (Windows) version and which AutoCAD version that worked BEFORE and the versions of OS/AutoCAD where the code stops working.
Also, since you are connecting to *.accdb file (Access2007 or later), are you sure the DB drive in the connectionstring is:
not
Provider=Microsoft.ACE.OLEDB.12.0
AFAIK, there is no "Microsoft.Jet.OLEDB12.0", rather the latest provider to Jet Engine is "Microsoft.Jet.OldDb.4.0", which no longer comes with later Windows OS (Win7 or later).
If you connect to *.accdb, the provider should be "Microsoft.ACE.OleDb.12.0". If you are using 64-bit AutoCAD, you need to either install 64-bit MS Access, or 64-bit MC Access DB Engine (free download), which is replacement to old Jet Engine.
Norman Yuan
Drive CAD With Code
I using windows7 64bit, microsoft access 64bit and autocad201864bit.
before i was using access32bit and autocad2015
i have no idea what happend and why it not working anymore?
norman.yuan
I assume that your computer (or any computer that runs the VBA code) had MS Access installed when it worked with AutoCAD 2015 (it must also have been 32-bit).
Now that you are using 64-bit AutoCAD, and its VBA now is also 64-bit, you MUST use MS Access DB Engine 64-bit. If you have 64-bit MS Office/MS Access installed, then you should be OK. However, in most cases with MS Office and/or MS Access installation, 32-bit MS apps are installed. Thus, you need to:
1. Change your MS Office suite/MS Access to 64-bit, which would get MS Access DB Engine installed.
or
2. Download and install 64 bit MC Access DB Engine (co-existing with 32-MS Office/Access app). This would be tricky, to say the least. You can search the net for how to install 64 MS Access DB Engine with MS Office suite 32bit co-existence.
IMO, 1 would be easier.
The other option is to move away from using Access DB for data storage to avoid the troublesome co-existence of 64-bit DB engine and 32-bit MS office suite issue.
Again, in the code's ConnectionString, the provider should be "Microsoft.ACE.OLEDB.12.0".
If you search this forum, you would find quite a few discussions on this topic in the past when people stated using 64-bit AutoCAD.
Norman Yuan
Drive CAD With Code
Does anyone can give me an example how it works now with 64bit how i can connected to an ms.access database.
if i know what code i need to use to make this connection i can fix mine program but now it doesnt work.
    With adoConnection
    End With
    Exit Sub
errInit:
    Set adoRC = Nothing
End Sub
norman.yuan
I am not sure if you have read my previous reply or not.
Before anyone can give any suggestion on the code itself, you need to tell:
DO YOU HAVE MS ACCESS 64-bit INSTALLED; OR DO YOU HAVE MS ACCESS DB ENGINE 64-bit INSTALLED? If not, it is not code issue (although there is code error as I pointed out).
Norman Yuan
Drive CAD With Code
