VBA connection ms.access vs AutoCAD (subscript out of range)
In the past i was allways use this vba file to make connection to ms.access database.
But on some reason it give me now connection error with "subscript out of range"
Private Sub Class_Initialize()
    On Error GoTo errInit
    Set adoConnection = New ADODB.Connection
    Set adoRC = New ADODB.Recordset
    With adoConnection
        .Open "Provider=Microsoft.JET.OLEDB.12.0;Data Source=" & "E:\TEST\Info64.accdb"
    End With
    On Error Resume Next
    ThisDrawing.SelectionSets("KADER").Delete
    Set objSSet = ThisDrawing.SelectionSets.Add("KADER")
    Exit Sub
errInit:
    MsgBox err.Description, vbCritical, "Ado Connection"
    Set adoConnection = Nothing
    Set adoRC = Nothing
    err.Raise err.Number, Me, err.Description
Ed__Jobe
Have you set a breakpoint and stepped through the code to see where the error is coming from?
Ed
How to post your code.
Norman_Yuan
You need to tell which OS (Windows) version and which AutoCAD version that worked BEFORE and the versions of OS/AutoCAD where the code stops working.
Also, since you are connecting to *.accdb file (Access2007 or later), are you sure the DB drive in the connectionstring is:
not
Provider=Microsoft.ACE.OLEDB.12.0
AFAIK, there is no "Microsoft.Jet.OLEDB12.0", rather the latest provider to Jet Engine is "Microsoft.Jet.OldDb.4.0", which no longer comes with later Windows OS (Win7 or later).
If you connect to *.accdb, the provider should be "Microsoft.ACE.OleDb.12.0". If you are using 64-bit AutoCAD, you need to either install 64-bit MS Access, or 64-bit MC Access DB Engine (free download), which is replacement to old Jet Engine.
Norman Yuan
Drive CAD With Code
I using windows7 64bit, microsoft access 64bit and autocad201864bit.
before i was using access32bit and autocad2015
i have no idea what happend and why it not working anymore?
Norman_Yuan
I assume that your computer (or any computer that runs the VBA code) had MS Access installed when it worked with AutoCAD 2015 (it must also have been 32-bit).
Now that you are using 64-bit AutoCAD, and its VBA now is also 64-bit, you MUST use MS Access DB Engine 64-bit. If you have 64-bit MS Office/MS Access installed, then you should be OK. However, in most cases with MS Office and/or MS Access installation, 32-bit MS apps are installed. Thus, you need to:
1. Change your MS Office suite/MS Access to 64-bit, which would get MS Access DB Engine installed.
or
2. Download and install 64 bit MC Access DB Engine (co-existing with 32-MS Office/Access app). This would be tricky, to say the least. You can search the net for how to install 64 MS Access DB Engine with MS Office suite 32bit co-existence.
IMO, 1 would be easier.
The other option is to move away from using Access DB for data storage to avoid the troublesome co-existence of 64-bit DB engine and 32-bit MS office suite issue.
Again, in the code's ConnectionString, the provider should be "Microsoft.ACE.OLEDB.12.0".
If you search this forum, you would find quite a few discussions on this topic in the past when people stated using 64-bit AutoCAD.
Norman Yuan
Drive CAD With Code
Does anyone can give me an example how it works now with 64bit how i can connected to an ms.access database.
if i know what code i need to use to make this connection i can fix mine program but now it doesnt work.
    With adoConnection
    End With
    Exit Sub
errInit:
    Set adoRC = Nothing
End Sub
Norman_Yuan
I am not sure if you have read my previous reply or not.
Before anyone can give any suggestion on the code itself, you need to tell:
DO YOU HAVE MS ACCESS 64-bit INSTALLED; OR DO YOU HAVE MS ACCESS DB ENGINE 64-bit INSTALLED? If not, it is not code issue (although there is code error as I pointed out).
Norman Yuan
Drive CAD With Code
