vba commands for drawing order
I'm using Acad2002 and am trying to figure out how to change the properties
of an object programatically so it is sent to the back of the drawing and
other line entities that are already existing are drawn/displayed on top of
this object.
Here's a very simple lisp. Use as is or translate to vba if you wish.
;;; Top.lsp - move to top of draworder
(defun c:Top (/ selset)
(prompt "Select entities to move to top of draworder. ")
(setq selset (ssget))
(command "copy" selset "" "@" "@") ;copy at same location puts ents higher
in database
(command "erase" selset "") ;erase previous ents
(command "redraw")
(princ)
Ed
"Brent" wrote in message
news:8E9EC6F5E9BF56ABCE9150FCF306498A@in.WebX.maYIadrTaRb...
properties
of
> this object.
> Thanks,
Ed -
Thanks for the reply. However, I'm wanting to send to the back of the
drawing just one entity/object. Instead of creating a selection set for all
the other entities in the drawing and erasing them and recreating them, it
seems that there should be a process in either vba or vlisp that can achieve
modifying just one entity? I would think there is a property value that can
be changed on an object that would flag this entity to be in the background.
BB
"Ed Jobe" wrote in message
news:91CC866D284D2161CA8F215AA72C3D2C@in.WebX.maYIadrTaRb...
higher
> in database
> (command "redraw")
> (princ)
> Ed
> properties
and
> of
> > this object.
> > Thanks,
In pure VB most objects have a Zorder property which is for affecting exactly what you are describing. Unfortunately Autodesk appears not to have implemented this functionality in their object model.
You could try investigating the Windows API SetWindowPos. The second parameter should be 1 (I think) for Send To Back. I've used this in VB but I'm not sure if it would work in the AutoCAD environment. (Sorry, no time to go into more detail.)
Regards
Wayne Ivory
IT Analyst Programmer
Wespine Industries Pty Ltd
Use the AutoCAD unsupported library - ADSKUNSUPP2000.ARX - which is
available on the 'net. It will allow for DrawOrder.
HTH,
Mike
___________________________
Mike Tuersley
AutoCAD Clinic
Rand IMAGINiT Technologies
Maybe you could try this. It's kinda hoky but it does kind of do what you
asked. You could add functionality that would allow you to select the
object(s) that you want the object to go under...
Sub vbaDrawOrder()
Dim obj As AcadObject, obj2 As AcadObject
Dim PickPoint As Variant
ThisDrawing.Utility.GetEntity obj, PickPoint, vbCr & "Select object to
send back:"
Set obj2 = obj.Copy
obj.Delete
ThisDrawing.SendCommand "DRAWORDER" & vbCr & "L" & vbCr & vbCr & "Back"
& vbCr
End Sub
Rogue
properties
of
> this object.
> Thanks,
