Passing an argument string from vb to a vba macro
I'm having trouble Passing an argument string from vb to a vba macro in a
batch plot routine I'm writing.
As vba does not have an drive list, dir list tools etc I decided to use vb6
to do the processing and call my vba plot macro which works on (VBA_LOADER
"K:/A2k/Vb-Macros/MyPlot.Dvb")(vl-vbarun "MyPlot") "A1 TO A3" from a menu
and tool button call.
But I cant pass the string with either
autocad.Application.ActiveDocument.SendCommand ("-vbarun" "MyPlot" "A1 TO
A3")
or
autocad.Application.RunMacro "Module1.MyPlot" "A1 TO A3"
in VB any clues ??
Also many thanks to the input I have received so far
hi, i'm sure there are many people much more qualified to answer this, but i think you need to make the argument variable globally visible, or if worst comes to worst just thisdrawing.SetVariable("USERS1") and have the plot procedure get it.
"Trevor Wickham" wrote in message
news:98C0E10F1EE0543E1E0FA95D0A52E636@in.WebX.maYIadrTaRb...
> Hi,
vb6
> A3")
> or
> in VB any clues ??
I don't know much about VBA, but if you can do this (i.e. use APIs and the
Split function) it could solve your problem:
Declare Function GetLogicalDriveStrings Lib "Kernel32" Alias
"GetLogicalDriveStringsA" (ByVal nBufferLength As Long, ByVal lpBuffer As
String) As Long
Dim DirPath As String
Dim ret As Long
Dim vDrivesPaths
DirPath = Space$(GetLogicalDriveStrings(0, DirPath))
ret = GetLogicalDriveStrings(Len(DirPath), DirPath)
vDrivesPaths = Split(DirPath, vbNullChar)
vDrivesPaths is now a variant array with each drive on the system.
I assume you could use Dir$ for directories?
--Art
Try the GetSetting() & SetSetting() functions to read/write to the registy's
application data area. Try the MS Common Dialog Control to list/select
drives, folders, & files.
John Goodfellow
irtfnm
use john at goodfellowassoc dot com
> Hi,
vb6
> A3")
> or
> in VB any clues ??
The suggestion worked a treat. Many thanks for the
info
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">hi,
it.
