VB6 and AutoCAD
VB6 and AutoCAD
VB6 and AutoCAD
I'm new to using VB6 in AutoCAD, but not new to using VB6.
How do I run AutoCAD commands in VB6? Is there some Active X control or DLL
that I need to load in order to use VB6 (not VBA) to run AutoCAD?
Thanks in advance!
Doug, Just make sure you have a reference set to the AutoCad type library,
and you are good to go, of course you must have acad installed on the same
machine.
Jacob Dinardi
Doug Cochran wrote in message
news:84DAD03D6C06A7FE3D2C5D4FF3810B7C@in.WebX.maYIadrTaRb...
Thanks in advance!
Thanks Jacob,
Forgive me for sounding "dense" but just how do I set this reference?
Would it be something like "Set Acad = GetObject(, "AutoCAD.Application")"
Where would this reference be placed i.e. as a public sub or private??!!!
An example code would be nice!
thanks again
"Jacob Dinardi" wrote in message
news:FE2EE7B0ACBA63E7AB6D577AC676ACB2@in.WebX.maYIadrTaRb...
> machine.
> Regards,
> Jacob Dinardi
> Hello,
DLL
> Thanks in advance!
"To do this in VB, select the References option from the Project menu to
launch the Reference dialog box. From the References dialog box, choose
AutoCAD Release 15 Type Library and press OK."
Sub Ch2_ConnectToAcad()
Dim acadApp As AcadApplication
On Error Resume Next
Set acadApp = GetObject(, "AutoCAD.Application")
If Err Then
Err.Clear
Set acadApp = CreateObject("AutoCAD.Application")
If Err Then
MsgBox Err.Description
Exit Sub
End If
End If
MsgBox "Now running " + acadApp.Name + _
" version " + acadApp.Version
End Sub
For more, see AutoCAD Online Manuals:
ActiveX and VBA Developers Guide
Ch. 2 - Understanding ActiveX Automation Basics
Using Other Programming Languages
Converting VBA Code to VB
Connecting to AutoCAD from Visual Basic
John Goodfellow
irtf'nm
use 'microtouch' in address to email
"Doug Cochran" wrote in message
news:E68A93872F4A5A219E0DA6E8755B3A99@in.WebX.maYIadrTaRb...
> Thanks Jacob,
> thanks again
library,
same
> > machine.
> > Regards,
> > Jacob Dinardi
> > Hello,
> DLL
> > Thanks in advance!
Thank you very much for shedding some light on this subject!
It worked!
Doug
"John Goodfellow" wrote in message
news:2D8B8F5CB6851D5BCC9F73AEBEFDA71E@in.WebX.maYIadrTaRb...
> If Err Then
> Err.Clear
> If Err Then
> Exit Sub
> End If
> End If
> End Sub
> John Goodfellow
> irtf'nm
> > Thanks Jacob,
private??!!!
> > thanks again
> library,
> same
> > > machine.
> > > Regards,
> > > Jacob Dinardi
> > > Hello,
or
> > DLL
> > > Thanks in advance!
Hai Doug Cochran,
I have a solution for your doubt, you can easily call autocad using vb6,
just you have to do some settings first
Please follow this
1. Open Vb6 and in Format menu click on References, Reference dialogue box
opens.
2. Select Autocad 2000 type Library
3. Apply and close the reference dialogue box.
Now open your form and add this code this will open Autocad, and you can
generate drawings same as in vba.
Private Sub command_click()
Dim myApp As AcadApplication
Dim acad As AcadDocument
Set myApp = CreateObject("AutoCAD.Application")
myApp.WindowState = acMax
myApp.ActiveDocument.WindowState = acMax
myApp.ActiveDocument.Width = 725
myApp.ActiveDocument.Height = 375
myApp.ActiveDocument.SendCommand "circle" & vbcr & "0,0" & vbcr & "5"& vbCr
End sub
I hope this will solve your problem,
Please mail back if you need any further help
thanking you
surender rao karanam
Regency Infotech pvt.ltd
#7-1-59/6, dharam karan road
Ameerpet, Hyderabad
Andhra pradesh
India
Pin 500016
> Hello,
DLL
> Thanks in advance!
this code writtin by karanam, is general code whatever version of autocad i am using, version of autocad is defind in the refrences list only or needs to be there within the code itself also, because this code didnt wok when i tried to use it with autocad 2008, although i choosed autocad 2008 type library.
