Populate a titleblock attribute with the DWGNAME system variable
I'd like to populate the attribute in a titleblock with the DWGNAME system variable. SHould I be posting to the LISP discussion group?
This might help.
In acad vba the following methods give the file name.
strDrawingName = ThisDrawing.Name ' Drawing name
or
strDrawingName = UCase(Left$(ThisDrawing.Name, Len(ThisDrawing.Name) -
4)) ' drawing name in UC less extension.
or
strDrawingName = Left$(ThisDrawing.Name, Len(ThisDrawing.Name) - 4) '
drawing name in LC less extension
To write the attribute
Private Sub FillBorder()
Dim objBorderBlockEnt As AcadEntity
Dim objBorderBlock As AcadBlock
Dim varAttribute As Variant
Dim varPick As Variant
Dim varRet As Variant
Dim intI As Integer
' Set Title Block Attribute Varibles
strDrawingNumber = "Not Defined"
strDrawingNumberTop = "Not Defined"
strTitleLine1 = "Blank"
strTitleLine2 = "Blank"
' User to select border
On Error Resume Next
SelectAgain:
ThisDrawing.Utility.GetEntity objBorderBlockEnt, varPick, vbCr &
"Pick any part of the border"
If Err <> 0 Then
Err.Clear
With ThisDrawing.Utility
.prompt vbLf & " Oops, I think you missed"
.GetString False, vbLf & " Press Enter to try again or ESC
to Chicken Out"
If Err <> 0 Then
Exit Sub
End With
GoTo SelectAgain
Set objBorderBlockRef = objBorderBlockEnt
If objBorderBlockRef Is Nothing Then
ThisDrawing.Utility.prompt vbCr & "That was not a block try
again"
GoTo SelectAgain
' Get Attribute Data
varAttribute = objBorderBlockRef.GetAttributes
For intI = LBound(varAttribute) To UBound(varAttribute)
Debug.Print varAttribute(intI).TagString &
varAttribute(intI).TextString
Select Case varAttribute(intI).TagString
Case "DRG_NO"
varAttribute(intI).TextString = strFileName
Case "DRG_NO_TOP"
varAttribute(intI).TextString = strDrawingNumberTop
Case "TITLE1"
varAttribute(intI).TextString = strTitleLine1
End Select
Next
Stewart Mills
