Vb 6.0 Project Run in All Autocad version(2007 ~ 2014 or over)
Dear All,
I'm using Vb.6.0 and Autocad 2007 to Autocad2014
I want to open a file in Autocad and do some mechanism( like insert, delete entity)
If I add project--> reference / Autocad 2007 Library its works good for Autocad 2007.
The problem is my client has different version of Autocad(2007~2014).If I select Autocad2007 library it will work perfectly for Autocad2007, but not other version of Autocad.
How can I customize the VB project to run all Autocad version(2007 ~ 2014)? If possible give me source sample.
Thanks in advance,
thenndral
Alfred.NESWADBA
EXE or as DLL?
One option is to remove the references to AutoCAD lib's and run your project with late-binding/all declarations as "Object" instead of the specific object-type.
I would not do that as this is difficult to develop, difficult t debug and teh chance for runtime errors is quite high as type conflicts are not recognized during compilation.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
