DynamicProperties emptied
TONELLAL
TONELLAL
I need to replace a dynamic block by its equivalent static block, transforming dynamic properties in attributes. My code is like :
Dyn_props = oBloc.GetDynamicBlockProperties
oBloc.ConvertToStaticBlock(NewName)
'... create one attribute for each property...
The problem is when I convert the block to static, all the properties values are lost ! The properties still exist, but they are all on "empty". If I debug on Dyn_props, I can see :
-before oBloc.ConvertToStaticBlock(NewName) : all the properties exist and have the right value in Dyn_props
-after I execute oBloc.ConvertToStaticBlock(NewName) : all the properties in Dyn_props still exist, but their value is Empty...
Any idea ?
Balaji_Ram
Sorry, i do not understand your requirement.
A dynamic block when converted to a static block cannot still have its dynamic property values and they are no longer relevant.
Can you please explain why you would expect a valid value to still be there for the static block ?
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
TONELLAL
A dynamic block has dynamic properties.
A static block has attributes.
What I need is to create a static block with attributes, each attribute corresponding a dynamic property.
When I convert a dynamic block in a static block, ok, it cannot have dynamic properties any more. So I create an object, named Dyn_props, to store dynamic properties before I convert the dynamic block. Once Dyn_props has a value, it is supposed to keep this value, even if the object which had the value doesn't exist anymore.
Example :
A=1
B=2
A = B    ---> the value of A is now 2
B = 3 ---> the value of A is always 2, it is not 3 !
So :
Dyn_props = oBloc.GetDynamicBlockProperties  ---> Dyn_props contains the dynamic properties from oBloc
oBloc.ConvertToStaticBlock(NewName)  ---> oBloc is now a static block, so it has no dynamic properties any more. But, before conversion, these dynamic properties have been stored in Dyn_props. Properties still exist in Dyn_props (I can see Description with its value, PropertyName with its value,etc and Value, but Value is now Empty.
