using vba to find a text from excel in autocad drawing
I want to write a vba code in excel that picks up un text from a cell in an excel worksheet and finds it on an autocad drawing.
here is my code:
Sub FindTextOnAcad()
  Dim Acad As acadapplication
  Dim acadfile As String
  acadfile = myfile.dwg
ActiveWorkbook.FollowHyperlink acadfile
Set Acad = GetObject(, "autocad.application")
Acad.ActiveDocument.sendcommand("find" & vbCr)
End Sub
This works well and opens the "Find" dialogue box in the acad drawing so I can imput the text from excel manually.
But what I need is to have vba directly find the required text without opening the "find" dialogue box
I tried the following: Acad.ActiveDocument.modelspace.find but it doesnt work
Thanks in advance for any suggestion
Almaroun
use SelectionSet object methods to group all TEXT objects
here's a quick code you can adapt to your needs
Option Explicit
Sub FindText()
    'Texts objects searching
    Dim myText As AcadText
    Dim ntexts As Integer, iText As Integer
    Dim myString As String
    Dim gpCode(0 To 1) As Integer
    Dim dataValue(0 To 1) As Variant
    Dim ssetObj As AcadSelectionSet
    myString = "mytext" ' text to find. here you can also use wild characters like "*mytext" or "*mytext*"
    'selecting texts objects in the active drawing
    gpCode(0) = 0:  dataValue(0) = "TEXT" ' here you can also use "TEXT,MTEXT" to pick up both object types
    gpCode(1) = 1:  dataValue(1) = myString
    On Error Resume Next
    Set ssetObj = ThisDrawing.SelectionSets.Item("TextSset")
    If Err <> 0 Then
        Set ssetObj = ThisDrawing.SelectionSets.Add("TextSset")
    Else
        ssetObj.Clear
    End If
    On Error GoTo 0
    ssetObj.Select acSelectionSetAll, , , gpCode, dataValue
    'handling texts object found
    ntexts = ssetObj.Count
    For iText = 0 To ntexts - 1
        ' do your stuff here
        ' for instance I'm listing all textstrings of the found objects
        Set myText = ssetObj.Item(iText)
        MsgBox ("Found :" & myText.TextString)
    Next iText
End Sub
 bye
Thanks a lot RICVBA,
this does solve my issue
Almaroun
I am getting error in this Line.
Type Mismatch.
Ravi
I modified the code slightly; I believe it's a bit cleaner:
replace "Dim ntexts As Integer, iText As Integer" and "Dim myText As AcadText" with "Dim AcadEnt As AcadEntity"
replace everything after " 'handling texts objects found" with:
For Each AcadEnt In ssetObj
  ' Do stuff in here; the text string can be accessed with AcadEnt.TextString
   MsgBox("Found : " & AcadEnt.TextString)
Next AcadEnt
This eliminates the clunky counting, which should fix your issue.
Type Mismatch.
Ravi
I am new to Autocad and am trying to achieve a very similar objective. I want to change the text of a tag in an attribute so I can generate unique drawings from a generic template.
I am trying the supplied code in the post here but am getting stuck on the following line:
The ssetObj is set to "nothing" when the line above is executed. It is as if no block and/or tag and text is selected.
Any help is appreciated!
Ed__Jobe
Did you include the line prior to that line? e.g. "On Error Resume Next"? Under normal execution, if the named selectionset doesn't exist, it skips to the next line and adds the selectionset.
Ed
How to post your code.
