Using the GetDistance method
Message 1 of 12
Is there a way to pass the value of a text box to the getdistanc e method?
Thanks in advance.
Rod Crowley
Replies (11)
Message 2 of 12
Value of a text box? I assume you mean the data is two points. Just
calculate it yourself. Try this http://code.acadx.com/visualbasic/013.htm
Ed
"Rodney Crowley" wrote in message
news:B34523D4807EE870EB5B7A33E026CDF8@in.WebX.maYIadrTaRb...
> Thanks in advance.
> Rod Crowley
Message 3 of 12
Is this what you're looking for?
Public Sub showDistance()
Const TEXT_BOX_STRING = "10.0,15.0"
Dim basePoint(0 To 2) As Double
Dim commaPosition As Integer
Dim distance As Double
Dim tempString As String
Dim xValue As Integer
Dim yValue As Integer
Dim zValue As Integer
' Convert the text string into numbers and store in an array.
On Error GoTo HANDLE_ERROR
commaPosition = InStr(1, TEXT_BOX_STRING, ",")
If commaPosition = 0 Then
MsgBox "Invalid input."
Exit Sub
Else
xValue = CDbl(Left$(TEXT_BOX_STRING, commaPosition - 1))
tempString = Right$(TEXT_BOX_STRING, commaPosition + 1)
commaPosition = InStr(1, tempString, ",")
yValue = CDbl(tempString)
zValue = 0#
Else
yValue = CDbl(Left$(TEXT_BOX_STRING, commaPosition - 1))
zValue = CDbl(tempString)
End If
End If
On Error GoTo 0
basePoint(0) = xValue
basePoint(1) = yValue
basePoint(2) = zValue
distance = ThisDrawing.Utility.GetDistance(basePoint, "Select second point.")
MsgBox CStr(distance)
Exit Sub
HANDLE_ERROR:
End Sub
Message 4 of 12
I am trying to take the value of a textbox, regardless of how it is entered,
and feed it into the getdistance method. In lisp if you pass a value through
the (getdist) function it will accept architectural units (1'-4 1/2"). I
would like to give my users the same option in vba, instead of writing a
function that will take 1'-4 1/2" and convert it to 16.5 I would rather pass
it through the getdistance method, something that does it for me already.
"Ed Jobe" wrote in message
news:F1596219339F86F7B9CB67CB2C459433@in.WebX.maYIadrTaRb...
> Ed
method?
> > Thanks in advance.
> > Rod Crowley
Message 5 of 12
Perhaps I don't understand you, but isn't (1'-4 1/2") already a distance?
The (getdist) function only accepts points, so it wouldn't accept (1'-4
1/2") without some reformatting.
Ed
news:A0D4FCEB309ABB4545A67C511A0371E1@in.WebX.maYIadrTaRb...
entered,
through
pass
> > Ed
> method?
> > > Thanks in advance.
> > > Rod Crowley
Message 6 of 12
I guess I am having trouble explaining what I am trying to do. with the
getdistance method, you can feed it a distance at the command line as an
alternative to picking points. I am looking to do the same thing, but
instead of from the command line, I would like it to pass it from a textbox.
when using the getdistance method from the command line, you can feed it a
value of 1'-4 1/2" and the get function will strip away all of the garbage
and store it as 16.5 in your variable. that is what i am trying to get.
news:18BEEB741A04E8F74B6CE0A0DC1449D1@in.WebX.maYIadrTaRb...
> Ed
> entered,
> through
> pass
already.
> > > Ed
> > method?
> > > > Thanks in advance.
> > > > Rod Crowley
Message 7 of 12
I think its sinking in now. I don't have time to try it, but how about the
SendKeys function?
Ed
news:D08C96B98C92438AE039707FEA8ED898@in.WebX.maYIadrTaRb...
textbox.
distance?
> > Ed
> > entered,
> > through
I
a
rather
> > pass
> already.
> > > > Ed
> > > method?
> > > > > Thanks in advance.
> > > > > Rod Crowley
Message 8 of 12
I have considered that, but only as a last option.
Thanks!
news:D7F9D8DC497815C62720924D43556F83@in.WebX.maYIadrTaRb...
> SendKeys function?
> Ed
> textbox.
a
garbage
> distance?
(1'-4
> > > Ed
> > > entered,
> > > through
1/2").
> I
writing
> a
> rather
> > > pass
> > already.
Just
> > > > > Ed
e
> > > > method?
> > > > > > Thanks in advance.
> > > > > > Rod Crowley
Message 9 of 12
Rodney,
What you are looking for is the DistanceToReal method of the Utility object.
Bobby C. Jones
www.AcadX.com
> Thanks in advance.
> Rod Crowley
Message 10 of 12
thank you! that is exactly what I am looking for!
"Bobby C. Jones" wrote in message
news:DCC555EAF361993DDEB92A71C316AA37@in.WebX.maYIadrTaRb...
> Rodney,
object.
> Bobby C. Jones
> www.AcadX.com
method?
> > Thanks in advance.
> > Rod Crowley
Message 11 of 12
I knew that! 🙂 Too many things goin' on. I thought of it just after I hit
send but didn't even have time to reply.
Ed
news:C9D4515C3777867C7D67444CF02FF834@in.WebX.maYIadrTaRb...
> > Rodney,
> object.
> > Bobby C. Jones
> > www.AcadX.com
> method?
> > > Thanks in advance.
> > > Rod Crowley
Message 12 of 12
You could use something similar to this to verify the input:
Public Function DistToReal(ByVal Text As String, ByVal FromUnit As Integer,
ByVal Reset As Double) As Double
Dim Dist As Double
If Text <> "0" Then
On Error Resume Next
Dist = ThisDrawing.Utility.DistanceToReal(Text, FromUnit)
Err.Clear
If Dist = 0 Then Dist = Reset
End If
DistToReal = Dist
End Function
R. Robert Bell, MCSE
www.AcadX.com
news:D29149A19C5A4A7DE16E9017D47D5CE8@in.WebX.maYIadrTaRb...
| Thanks!
the
| > SendKeys function?
| > Ed
the
an
| > textbox.
it
| a
| garbage
get.
| > distance?
| (1'-4
| > > > Ed
is
| > > > entered,
value
| > > > through
| 1/2").
| > I
| writing
| > a
| > rather
| > > > pass
| > > already.
| Just
| > > > > > Ed
getdistanc
| e
| > > > > method?
| > > > > > > Thanks in advance.
| > > > > > > Rod Crowley
