Calling macro from another loaded macro
Message 1 of 8
Is it possible to call a macro from another loaded DVB file's modules.
When I call one it says that it is not defined.
If yes how?
Thanks.
Replies (7)
Message 2 of 8
If you reference the other dvb, it will always be loaded if it isn't
already. Then refer to the macro with the full qualification to the macro:
dvbProjectName.ModuleName.MacroOrFunctionName.
Ed
"Yves" wrote in message
news:1DF2E08718E17EBC5E063ED0BECCA41A@in.WebX.maYIadrTaRb...
> Hi,
> If yes how?
> Thanks.
Message 3 of 8
Thanks Ed,
But the macro I'm trying to run is loaded, well, I see it in me VBA Editor,
and when I type in a new sub the name of the current project, when I type
the ".", all the available Subs, Modules, forms, appear in a dropdown list,
But when I type the name of the other project, nothing appends, and I get
Variable not defined.
To my surprise all the project I created so far, had the name ACADProject, I
renamed them, is it OK?
Thanks.
"Ed Jobe" a écrit dans le message de
news:646DFBD18F5649D70DAE75DDA633B2A2@in.WebX.maYIadrTaRb...
> Ed
> > Hi,
> > If yes how?
> > Thanks.
Message 4 of 8
Naturally, unique names will help. The behavior you describe is called
Intellisense. It only happens for early binding, not late binding. To
acheive early binding, reference the other project (Tools>References), even
though it is loaded.
Ed
news:7119403B5736B0422E1EB016E8E06209@in.WebX.maYIadrTaRb...
> Thanks Ed,
Editor,
list,
I
> Thanks.
macro:
> > Ed
> > > Hi,
> > > If yes how?
> > > Thanks.
Message 5 of 8
After a couple of try and error I found that in the reference tables, there
was my MacroCAD!!!
But for Late binding... what's the name of a DVB file for me to bind at
execution?
news:16C571F144296327D6CABADCAF82E3E8@in.WebX.maYIadrTaRb...
even
> Ed
> > Thanks Ed,
> Editor,
type
> list,
get
ACADProject,
> I
> > Thanks.
> macro:
> > > Ed
> > > > Hi,
modules.
> > > > If yes how?
> > > > Thanks.
Message 6 of 8
Binding is not something that you do, at least directly. That's a subject
better handled by you doing a little research on to get the handle of it.
Here is something from Help:
Object Data Type
Object variables are stored as 32-bit (4-byte) addresses that refer to
objects. Using the Set statement, a variable declared as an Object can have
any object reference assigned to it.
Note Although a variable declared with Object type is flexible enough to
contain a reference to any object, binding to the object referenced by that
variable is always late (run-time binding). To force early binding
(compile-time binding), assign the object reference to a variable declared
with a specific class name.
If you need more info, check out MSDN.
Ed
news:87A361F6604DF9CDA4C3F01B1B0529CB@in.WebX.maYIadrTaRb...
> Thanks,
there
> was my MacroCAD!!!
> execution?
> even
> > Ed
> > > Thanks Ed,
> > Editor,
> type
> > list,
> get
> ACADProject,
> > I
> > > Thanks.
> > macro:
> > > > Ed
> > > > > Hi,
> modules.
> > > > > If yes how?
> > > > > Thanks.
Message 7 of 8
Thanks, but that was my question, maybe badly asked I confess, I wanted to
know how to declare a variable to get that early binding.
I expexted to do:
Dim var as MacroCad
Set car as new MacrocaD
That would be early binding.
I get an error (Expected user defined, not project)
If I put a reference to the project (MacroCad),
Then the following works.
MacroCad.Subs.seekLayer("TOPOLOGY", Doc), but only if it is referenced, so
is it the only way to access this project, having it referenced on all the
projects I build.
Thanks again.
And it is working.
news:E57016511E62D3B267492BD289F583B9@in.WebX.maYIadrTaRb...
> Object Data Type
have
that
> Ed
> > Thanks,
> there
> > was my MacroCAD!!!
> > execution?
> > even
> > > Ed
> > > > Thanks Ed,
> > > Editor,
> > type
dropdown
> > > list,
I
> > get
> > ACADProject,
> > > I
> > > > Thanks.
isn't
the
> > > macro:
> > > > > Ed
> > > > > > Hi,
> > modules.
> > > > > > If yes how?
> > > > > > Thanks.
Message 8 of 8
Binding takes place when the dvb loads. It refers to how each object knows
what its supposed to do. When the vba environment initializes, it has to
load or bind the code to each object. If that code comes from a source
external to where the object is declared, it can be bound at load time or at
runtime. The modules you referenced are bound at loadtime. You don't need to
dim a var, just use the module. If you create a new object, as from a class
object in the referenced dvb, then you need to dim an object variable as
noted in the help topic I sent.
Ed
news:F8241DCEA83F6C64EE86ADC04B579CA2@in.WebX.maYIadrTaRb...
> I expexted to do:
> Dim var as MacroCad
> projects I build.
> Thanks again.
> And it is working.
subject
it.
> > Object Data Type
> have
to
> that
declared
> > Ed
> > > Thanks,
> > there
> > > was my MacroCAD!!!
at
> > > execution?
called
To
(Tools>References),
> > > even
> > > > Ed
> > > > > Thanks Ed,
VBA
> > > > Editor,
I
> > > type
> dropdown
> > > > list,
and
> I
> > > get
> > > ACADProject,
> > > > I
> > > > > Thanks.
> isn't
> the
> > > > macro:
> > > > > > Ed
> > > > > > > Hi,
> > > modules.
> > > > > > > If yes how?
> > > > > > > Thanks.
