User-defined type Error
I am trying to write a program to do the following :
-Select a folder containing AutoCAD blocks;
-Get the volume of the block (containing several 3D solid elements);
-Copy the information into an Excel table.
I am writing the program from VBA in Excel, as i want to launch it from an Excel master file.
The problem I have is that I can't get AutoCAD object types to compile (such as AcadEntity and Acad3dSolid). The error message will be "User-defined type not defined". I tried to use the "set" command without much success.
If I copy/paste the code in the AutoCAD VBA, the AutoCAD-specific variable type will compile, but not the Excel-specific lines.
Here is what I have now :
Option Explicit
Sub LoopAllFilesInFolder()
'SOURCE: www.TheSpreadsheetGuru.com
'MODIFIED BY: Etienne
Dim myPath As String
Dim myFile As String
Dim myExtension As String
Dim FldrPicker As FileDialog
Dim AcadApp As Object
Dim mydwg As Object
Dim myBlock As String
'Optimize Macro Speed
  'Application.ScreenUpdating = False
  'Application.EnableEvents = False
  'Application.Calculation = xlCalculationManual
'Retrieve Target Folder Path From User
  Set FldrPicker = Application.FileDialog(msoFileDialogFolderPicker)
    With FldrPicker
      .Title = "Select A Target Folder"
      .AllowMultiSelect = False
        If .Show <> -1 Then GoTo NextCode
        myPath = .SelectedItems(1) & "\"
    End With
'In Case of Cancel
NextCode:
  myPath = myPath
  If myPath = "" Then GoTo ResetSettings
'Target File Extension
  myExtension = "*.dwg"
'Target Path with Ending Extention
  myFile = Dir(myPath & myExtension)
'Loop through each Autocad file file in folder
  Do While myFile <> ""
    'Set variable equal to opened workbook
      myBlock = myPath & myFile
      Set AcadApp = GetObject(, "AutoCAD.Application")
      Set mydwg = AcadApp.Documents.Open(myBlock)
    'Ensure Workbook has opened before moving on to next line of code
      DoEvents
    Call CalculateMass(mydwg)
    'Doesn't save and Close Workbook
      mydwg.Close SaveChanges:=False
    'Ensure Workbook has closed before moving on to next line of code
      DoEvents
    'Get next file name
      myFile = Dir
  Loop
'Message Box when tasks are completed
  MsgBox "Task Complete!"
ResetSettings:
  'Reset Macro Optimization Settings
    Application.EnableEvents = True
    Application.Calculation = xlCalculationAutomatic
    Application.ScreenUpdating = True
End Sub
Sub CalculateMass(mydwg As Object)
Dim hasBlock As Boolean
Dim tEnt As AcadEntity
Dim tEntSolid As Acad3DSolid
Dim totalVolume As Double
Dim volume As Double
'Set tEnt = AutoCAD.AcadApplication.ActiveDocument.ModelSpace.Entity
  hasBlock = False
  totalVolume = 0
For Each tEnt In ThisDrawing.ModelSpace
    If TypeOf tEnt Is Acad3DSolid Then
        Set tEntSolid = tEnt
        volume = tEntSolid.volume
        totalVolume = totalVolume + volume
    If TypeOf tEnt Is AcadBlock Then
        hasBlock = True
Next
End Sub
Ed__Jobe
It sounds like you haven't set a reference to the AutoCAD type library. In the xl vba ide, go to Tools>References and select the AutoCAD 20XX Type Library.
Ed
How to post your code.
Alfred.NESWADBA
You have to add references to the VB-project like here:
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Thank you very much, both of you!
