Running MASSPROP command through VBA
I'd like to use VBA to automatically run MASSPROP and save the results as a file. I'd do this manually by typing:
massprop enter
all enter enter enter
y enter enter
so to do this in VBA I tried the command
SendCommand ("_massprop" & vbCr & "_all" & vbCr & vbCr & vbCr & "_y" & vbCr & vbCr)
but it only gets to the "Write analysis to file?" stage and then stops
I'm very new to VBA in AutoCAD and AutoCAD generally so I'd appreciate any help.
Thanks!
Ed__Jobe
This happens because vba can't switch focus to the file dialog. Before you run SendCommand, use the SetVariable method to set FILEDIA to 0, then set it back to 1 when you are done.
Ed
How to post your code.
Thanks for your reply, I've googled what you suggested and tried a few things but they haven't worked. How would you recommend coding that?
Thanks!
Ed__Jobe
ThisDrawing.SetVariable "FILEDIA", 0
ThisDrawing.SendCommand "massprop"
ThisDrawing.SetVariable "FILEDIA", 1
Ed
Hi, thanks again for the quick response, I implemented that and I can see the changes it has made but my code still doesn't run to completion.
My full code (running from VBA in Excel) is:
Sub Main()
    Dim ACAD As AcadApplication 'Create ACAD variable of type AcadApplication
    Set ACAD = GetObject(, "AutoCAD.Application") 'Get a running instance of the class AutoCAD.Application
    ACAD.ActiveDocument.SetVariable "FILEDIA", 0
    ACAD.ActiveDocument.SendCommand ("massprop" & vbCr & "all" & vbCr & vbCr & vbCr & "y" & vbCr & vbCr) 'Print a message to the AutoCAD® command line
    ACAD.ActiveDocument.SetVariable "FILEDIA", 1
End Sub
When I run this then go into AutoCAD the command line looks like:
but if I then click on the command line it switches to this:
Thanks for all the help!
Tom
Ed__Jobe
There's something about that command that it won't respond to scripting. I tried a plain old scr and it does the same thing.
Ed
I was looking at something else and by chance stumbled across a reference to QAFLAGS. It turned out that changing this to 2 made the script work.
My working code is:
Sub Main()
    ACAD.ActiveDocument.SendCommand ("qaflags" & vbCr & "2" & vbCr) 'This is needed for the operation
    ACAD.ActiveDocument.SendCommand ("massprop" & vbCr & "all" & vbCr & vbCr & "y" & vbCr & vbCr) 'Print a message to the AutoCAD® command line
End Sub
Thanks for your help!
Tom
