user defined block in mleader
mo126940
mo126940
I'm sorry, but my problem is that I can not use a user-defined block in a mleader using VBA, and I do not find code examples explaining how to do it ...
If i try
Sub InsMultileaderUBlock()
Dim oML As AcadMLeader
Dim points(0 To 14) As Double
' Define the leader points
points(0) = 1: points(1) = 1: points(2) = 0
points(3) = 1: points(4) = 2: points(5) = 0
points(6) = 2: points(7) = 2: points(8) = 0
points(9) = 3: points(10) = 2: points(11) = 0
points(12) = 4: points(13) = 4: points(14) = 0
Dim i As Long
Set oML = ThisDrawing.ModelSpace.AddMLeader(points, i)
oML.ContentType = acBlockContent
oML.ContentBlockName = "POS_R"
oML.ContentBlockType = acBlockUserDefined
oML.ArrowheadSize = 10
oML.leaderType = acSplineLeader
oML.TextRightAttachmentType = acAttachmentMiddle
oML.TextLeftAttachmentType = acAttachmentMiddle
End Sub
 when i define oML.ContentBlockType = acBlockUserDefined , the system say :
Thanks in advance ...
ambrosl
Are you trying to assign a Block to the content or arrowhead of the MLeader?  In either case, you don't need to set the ContentBlockType or ArrowheadType properties to a value of acArrowUserDefined.  Simply assign the user-defined block name to ContentBlockName or ArrowheadBlock properties.
Comment out oML.ContentBlockType = acBlockUserDefined and the code should execute as expected.
Lee Ambrosius
Senior Principal Content Experience Designer
For additional help, check out the AutoCAD Developer Documentation
mo126940
Hi Ambrosl,
now the code work very fine, thank you very much.
Bye
