How to access the position of an specific entity in a block using VBA
ilovejingle
ilovejingle
I have a drawing with many block references of different block.
each block reference contains several  3D solids
one of the 3d solids is of my interests. it is a 3D solid box
I want to find the position of the 3D solid box in each of the block references. namly the 3D coordinates of it  reference to the block insertion point or the WCS zero.
is there a way to do it using VBA ?
Regards
norman.yuan
You need to loop through entities in the block definition(AcadBlock) to find the entity in interest, and its position to the block's base point (0,0,0). Then for each of the block references, factor in the block refernece's insertion point.
The pseudo code would look like:
'' Get the position of the Solid inside the block definition
Dim blk as AcadBlock
set blk=ThisDrawing.Blocks("myBlock")
Dim ent as AcadEntity
Dim position(0 to 2) As Double
For Each ent in blk
  If TypeOf ent Is AcadSolid And [some other condition to make sure it is the target, if necessary] Then
    position=[Get a set of coordinate from the Solid, such as one of its corner...]
    Exit For
Next
'' Get the positions related to the drawing's 0, 0,0 (such as ModelSpace's World Origin:
Dim bref As AcadBlockReference
Dim pos() As Variant
Dim i As Ineter
For Each ent in ThisDrawing.ModelSpace
  If TypeOf ent Is AcadBlockrefernece Then
    Set bref=ent
    If UCase(bref.EffectiveName)=UCase("myBlock") Then
      ReDim pos(i)
      pos(i)(0)=bref.InsertionPoint(0) + position(0)
      pos(i)(1)=bref.InsertionPoint(1) + position(1)
      pos(i)(2)=bref.InsertionPoint(2) + position(2)
      i=i+1
    End if
  End if
Next
Norman Yuan
Drive CAD With Code
ilovejingle
Thanks very much, I didn't know it can loop though all the elements in a block definition, now it works perfectly.
arazaSNXR7
Thank you so much!
