type mismatch (error13) - get coords off AcadPoint
Hi, is there a way to get coords of a defined Acadpoint ?
If I want to "print" the coords it says "error 13 - type mismatch"
Any idea why ? Thanks.
Sub point()
Dim pointObj As AcadPoint
Dim location(0 To 2) As Double
Dim retCoord As Variant
location(0) = 5#: location(1) = 5#: location(2) = 0#
Set pointObj = ThisDrawing.ModelSpace.AddPoint(location)
retCoord = pointObj.Coordinates
Debug.Print retCoord
End Sub
norman.yuan
You probably already knew that AcadPoint.Coordinate is Variant type (an array of 3 Double values).
Debug.Print can print data types that can be implicitly converted to a string value by VBA. In your case, VBA cannot do the conversion, so you need to do the print like this:
Debug.Print retCoord(0) & ", " & retCoord(1) & ", " & retCoord(2)
Norman Yuan
Drive CAD With Code
That's it. You're right I already tried to print the entitites of the arry, didn't work though. But your code works, thanks.
