Old VBA (32 Bit) Does Not Run on New 64 Bit
Hi
i am trying to install AutoCAD 2018 VBA module 64-bit for autocad 2018 but getting error Microsoft Visual C++ Runtime Library Debug Assertion Failed!
please help me put of this issue.
norman.yuan
Your description of the issue does not match the title of your post, which is very confusing?
Is your problem not able to install AutoCAD 64-bit VBA Enabler, or you have installed 64-bit VBA but your old 32-bit VBA code does not run?
Also, you'd better mention which version of AutoCAD you are using (and 32 or 64-bit?).
Norman Yuan
Drive CAD With Code
First,  you can't install 64bit vba  in AutoCAD 32bit
what you have to do is first install AutoCAD 2018 64bit  and then the 64but vba module
or your problem is that you try to run code in  the wrong 64 or 32 bit module.  it is possible but you have to change your declerations
here you can see how to use both   https://docs.microsoft.com/en-us/office/vba/language/reference/user-interface-help/ptrsafe-keyword
