Style/Performance Question
Message 1 of 1
I have declared a number of "global" variables at the top of a module for
use by sundry procedures. Should I declare them Private if I want to ensure
they are only accessed within that module?
Also, what happens to successive calls to open an ADODB.Connection? For
example, I would like to open a connection in a top-level procedure for use
by all procedures called after it and then close it when everything is done.
However, I'd also like to check that the connection has been made and
re-establish it in subsequent procedures. If I simply call .Open is the
connection broken and remade? Is that expensive performance-wise? I have a
small example included.
I know that this will work, but is it good style? Is there a better way to
do what I'm after? Should I pass the ADODB.Connection object down the call
graph as a parameter to the procedures that use it? Is it good practice to
declare the connection string the way I've done?
Cheers,
Rob
Option Explicit
Public cn As New ADODB.Connection
Public rsData As New ADODB.Recordset
Const strDBConnect = "DRIVER={MySQL ODBC 3.51 Driver};" & _
"SERVER=10.20.1.72;" & _
"DATABASE=caddb;" & _
"USER=autocad;" & _
"PASSWORD=drAw4mE;" & _
"OPTION=3;"
Public Sub TopLevelProcedure()
' Initialize Global Connection object
cn.ConnectionString = strDBConnect
cn.Open
NextLevelProcedure
'Call some other things here
cn.Close
Set rsData = Nothing
Set cn = Nothing
End Sub
Public Sub NextLevelProcedure()
' Don't assume that we have a connection object.
cn.Open
strSQL = "INSERT INTO t1 (a, b, c) VALUES (1, 2, 3);"
Set rsData = cn.Execute(strSQL)
End Sub
Replies (0)
