Step through text boxes (objects) with code
VBA noobie question . . .
Is it possible to step through text boxes (or any object) with code
Here's a rough sample trying to manipulate TextBox1 and TextBox2:
sub tboxmod()
Dim n As Integer
Dim Tname As String
For n = 1 To 2
Tname = "TextBox" & n
Dim TBox As TextBox
Set TBox = Tname
TBox.Text = "n"
Next n
End Sub
Thanks in advance
I don't reallt understand what you are doing. If you have a dialogue which a TextBox property on it, you should handle the TextBox_Change event handler to keep track of changes.
Also, you might want to look at the .Value property as opposed to the .Text property.
Hope this helps.
Andrew
Check out the last few posts in the thread "Object Variable Not Set Error" I had tacked it on as an extra question, and I think the answers might help.
