Strings won't concatenate
Message 1 of 13
This is driving me nuts. I have two string variables. I can display them
in message boxes individually, but when I try to concatenate them, I get
only the first string. I have jumped through all kinds of hoops trying to
figure out why, and I'm stumped. I thought maybe someone here had seen this
before.
Here is my code. I have noted the problem area.
Option Explicit
Option Compare Text
Sub UnBloat()
Dim files As Variant
Dim ComDlg As CommonDialog
Set ComDlg = New CommonDialog
With ComDlg
.DialogTitle = "Select files: "
.DefaultExt = "dvb"
.Filter = "VBA Projects|*.dvb"
.Flags = OFN_EXPLORER Or OFN_ALLOWMULTISELECT Or OFN_HIDEREADONLY
.InitDir = "T:\Acad2000\VBA"
If .ShowOpen Then
files = .ParseFileNames
Else
GoTo NoFilesSelected
End If
End With
Dim objIDE As Object
Dim i As Integer
Dim strFileName As String
Dim strBuildFile As String
Dim ProjLoaded
Dim objProj As Variant
Dim objFileSys As Object
Dim strFldrName As String
Dim objComp As Variant
Dim objRef As Variant
Set objIDE = Application.VBE
For i = LBound(files) To UBound(files)
strFileName = files(i)
ProjLoaded = False
For Each objProj In objIDE.vbprojects
strBuildFile = StrConv(objProj.buildfilename, vbUpperCase)
strBuildFile = Replace(strBuildFile, "\\FILESERVER\PROJECTS",
"T:")
strBuildFile = Replace(strBuildFile, "\\FILESERVER\CHUCK$",
"Z:")
strBuildFile = Replace(strBuildFile, ".DLL", ".DVB")
strFileName = StrConv(strFileName, vbUpperCase)
If strBuildFile = strFileName Then
ProjLoaded = True
Exit For
End If
Next
If ProjLoaded = False Then
LoadDVB strFileName
Set objProj = objIDE.vbprojects(objIDE.vbprojects.Count)
End If
MsgBox "Project: " & objProj.Name
'THE FOLLOWING STRING VARIABLE APPEARS TO BE THE SOURCE OF THE PROBLEM.
'IF I SET IT TO AN EXPLICIT VALUE, IT CONCATENATES PROPERLY.
strFldrName = Replace(strFileName, ".DVB", "")
MsgBox "FileName: " & strFileName
' Set objFileSys = CreateObject("Scripting.FileSystemObject")
' objFileSys.createfolder strFldrName
For Each objComp In objProj.vbcomponents
'THE SELECT CASE STRUCTURE BELOW IS WHERE I AM TRYING TO CONCATENATE THE
STRINGS.
Select Case objComp.Type
Case 1
MsgBox "Component: " & objComp.Name
MsgBox "Export to: " & strFldrName & "\" & objComp.Name
& ".bas"
Case 2
& ".cls"
Case 3
& ".frm"
End Select
Next
For Each objRef In objProj.references
MsgBox "Reference: " & objRef.Name & " - " & objRef.fullpath
Next
Next i
Set objIDE = Nothing
Set objProj = Nothing
Set objFileSys = Nothing
Set objComp = Nothing
Set objRef = Nothing
NoFilesSelected:
Set ComDlg = Nothing
End Sub
Thanks in advance.
Chuck Gabriel
Coggin Carrara, Inc.
Replies (12)
Message 2 of 13
Sorry about the word wrap. I'll try to do better next time. I promise.
Message 3 of 13
Are you sure the source of the problem is you? Take a look at the
filename being returned by the CommonDialog class *before* you attempt
to use it for anything else and ensure that it does not include any
trailing NULL characters.
http://www.acadx.com
Message 4 of 13
Hi Frank,
Thanks for the tip. I hate to be lame, but how would I go about checking
for
those trailing NULL characters and then removing them?
Chuck
"Frank Oquendo" wrote in message
news:F451CA4012D1E8168FD2031DC653801A@in.WebX.maYIadrTaRb...
Message 5 of 13
So much for my attempt at doing better with the word wrap 😛
"Chuck Gabriel" wrote in message
news:549088121BEE2C2669872F9D1B7B53C2@in.WebX.maYIadrTaRb...
> Hi Frank,
> for
> Chuck
Message 6 of 13
Put a breakpoint in your code where you try to concatenate the
filename. You can either drag and drop the filename variable into the
watch window or just hover your cursor it in the code. A well-formed
string will look like this:
"test.dwg"
One with trailing nulls will have a lot of space or other garbage on
the end of the string. As for fixing it, I believe this is a problem
in the CommonDialog class itself. I fixed it once but never got around
to posting the fix and now I've lost it. Let me know what you find and
we'll work on the solution together so no one else will have to go
through this.
> Hi Frank,
checking
> for
> Chuck
Message 7 of 13
What about using the Left function to trim ".dvb" from the file name, rather
then using the Replace function. You can search for ".DVB" or "." from the
right with InStrRev to get the position, then use Left to truncate the
string.
Glen
news:33CE13B416A42694DF91C12731849CE9@in.WebX.maYIadrTaRb...
this
> before.
> Option Explicit
> Option Compare Text
> Sub UnBloat()
> With ComDlg
> .DefaultExt = "dvb"
> If .ShowOpen Then
> Else
> End If
> End With
> Dim i As Integer
> Dim ProjLoaded
> ProjLoaded = False
> "T:")
> "Z:")
> ProjLoaded = True
> Exit For
> End If
> Next
> LoadDVB strFileName
> End If
> STRINGS.
> Case 1
objComp.Name
> & ".bas"
> Case 2
objComp.Name
> & ".cls"
> Case 3
objComp.Name
> & ".frm"
> End Select
> Next
> Next
> Next i
> NoFilesSelected:
> End Sub
> Thanks in advance.
> Chuck Gabriel
Message 8 of 13
I put a breakpoint in at the following line:
Then I added a watch to the variable strfilename.
This is the value I got.
"D:\Backup\ACAD2000\VBA\CommonDialog.dvb"
Does that make any sense?
Chuck
----- Original Message -----
Newsgroups: autodesk.autocad.customization.vba
Sent: Monday, June 11, 2001 4:37 PM
Subject: Re: Strings won't concatenate
> "test.dwg"
> through this.
Message 9 of 13
Chuck -
It isn't what you are doing that is causing word wrap. Unfortunately the
web view side of the newsgroups does not carry across with the carriage
returns or paragraph breaks. It is a known problem on the list for a
fix.
The newsgroup reader side does show your code correctly indented and
wrapped.
The two URLs for VBA are:
The VBA newsgroup for NTTP newsgroup readers can be found at
news://discussion.autodesk.com/autodesk.autocad.customization.vba.
You may also access the VBA discussion group via the HTTP web-based
forums at http://discussion.autodesk.com/WebX?14@@.ee77f0d.
Anne Brown
Manager, Moderator
Autodesk Product Support discussion groups
Discussion Q&A: http://www.autodesk.com/discussion
Message 10 of 13
Yes, that makes sense. It's not the correct result but it makes
sense. The fault is indeed in the CommonDialog class. I took a look
and found that the ShowOpen and ShowSave methods weere not stripping
all the nulls out of the strings.
I fixed it and attached it to this message. I'll post the updated copy
to my site tonight. Thanks for helping me with this one.
news:D7C296F1C363D8E3DCC7961295FFE07F@in.WebX.maYIadrTaRb...
> Chuck
Message 11 of 13
Chuck
Private Function strTrimNull(strVal As String) As String
Dim intPos As Integer
intPos = InStr(1, strVal, vbNullChar)
Select Case intPos
Case Is > 1
strTrimNull = Left$(strVal, intPos - 1)
Case 0
strTrimNull = strVal
Case 1
strTrimNull = vbNullString
End Select
End Function
Hope this is some help.
Ian
On Mon, 11 Jun 2001 16:30:02 -0700, "Chuck Gabriel"
>Chuck
>From: "Frank Oquendo"
>> "test.dwg"
>> through this.
Message 12 of 13
Thank me? THANK YOU!! I use CommonDialog.cls all over the place.
It is invaluable.
Thanks again Frank.
news:13A86ECDA2193FC3255F7DC4B08FEE06@in.WebX.maYIadrTaRb...
Message 13 of 13
Many thanks to all who responded.
Consider the problem solved.
I went with Frank's solution, since it involved basically no work on my part, but I have
added the other ideas to my rapidly growing library of code stolen from other people.
Thanks again.
