ActiveLayout not activ?!!
Hy, here is my problem,
I make a new layout:
Set New_Lay = ThisDrawing.Layouts.Add("NewLayout")
I set it activ:
ThisDrawing.ActiveLayout = New_Lay
And then i make this:
Set PView = ThisDrawing.Paperspace.AddPViewport(Cen_Pt, Length, High)
The problem is, that the new PViewport is not im my Layout, it is in the
last activ
layout.
Why, is this a bug or should i make holidays?
Thank for every answer
Bernd
It is probably failing at:
Try this:
Set ThisDrawing.ActiveLayout = New_Lay
"Bernd Cuder" wrote in message
news:CA67701AB01BA65941A123643CD614A8@in.WebX.maYIadrTaRb...
> I set it activ:
> last activ
> layout.
> Bernd
No, that is not the problem,
when i set the layout activ it is activ an visible, but in the
paperspace object is the last layout activ, so the viewport is
create there?
Bernd
"Rodrigo Prati" schrieb im Newsbeitrag
news:4148787B877096D025FB5111951FB6FB@in.WebX.maYIadrTaRb...
> Try this:
> > I set it activ:
> > last activ
> > layout.
> > Bernd
... after setting your active layout, try setting mspace to false: (this
will ensure that you are in the paperspace portion of the layout)
ThisDrawing.Mspace = false
ok -- i guess that didn't work.... try this?
Set PView = ThisDrawing.ActiveLayout.Block.AddPViewport(Cen_Pt, Length,
High)
Thanks Lanny your code works fine, but i now know the problem:
I intialize every drawing in this
Set Pspace=ThisDrawing.Paperspace
When i create a new layout, the pspace object will not be actualize, so i
call
the set function again and it works.
Bernd
"Lanny Schiele" schrieb im Newsbeitrag
news:06DF460300E397E2863F9221EFAF7644@in.WebX.maYIadrTaRb...
> High)
Lanny, you're a genius!! This line of code, translated into vlisp, has
finally solved a problem of mine that I've been having for a long time!!
Just wanted to say thanks.
Bobby C. Jones
p.s. - Can anyone explain to me why the paperspace collection does not
always stay in sync with the current layout?? Is it a bug, or is it
designed specifically to confuse us?
"Lanny Schiele" wrote in message
> High)
