Starting shell command with Visual Basic
Message 1 of 8
I am trying to start AutoCAD 2000 with a Visual Basic program using the Shell Command.
On one computer this works fine, but the other computer it will not work at all.
I have narrowed it down to AutoCAD not wanting to start, I think, because I can start notepad just fine.
I am trying to start ACAD and then have it run a script file immediately.
Any help would be greatly appreciated.
Replies (7)
Message 2 of 8
You'd have better luck in the VBA group.
VISUAL BASIC CUSTOMIZATION
The Visual Basic Customization newsgroup can be accessed in
either of the following ways:
By NNTP newsgroup reader at
news://discussion.autodesk.com/autodesk.autocad.customization.vba
By HTTP (web-based) interface at
http://discussion.autodesk.com/WebX?14@@.ee77f0d
-Jason
Member of the Autodesk Discussion Forum Moderator Program
"mantin999" wrote in message
news:f14aa6b.-1@WebX.maYIadrTaRb...
not work at all.
immediately.
Message 3 of 8
Load the acad.tlb library so AutoCAD is exposed to Visual Basic
Dim acadOBJ as AutoCAD.Application
'Visual Basic 6.0
Set acadOBJ = createObject(, "AutoCAD.Application")
' Visual Basic.NET
acadOBJ = createObject(, AutoCAD.Application)
acadObj.Visible = true
Now AutoCAD is started and visible
"Jason Piercey" wrote in message
news:8959DD0C03F883C4A5FDF9E8A761D8AC@in.WebX.maYIadrTaRb...
> -Jason
> not work at all.
> immediately.
Message 4 of 8
I did the following and it worked on one computer, but another computer it didn't work.
It came back with:
Runtime error 429
Active X Component can't create object.
>Load the acad.tlb library so AutoCAD is exposed to Visual >Basic
>'Visual Basic 6.0
>' Visual Basic.NET
Message 5 of 8
Do you have the same versions of AutoCAD loaded [or AC loaded at all the second machine]? What about their installation location? Are they the same? Are you using a hardcoded path in your application? More complete code example might help determine the challenge.
Joe
Message 6 of 8
Below is the actual code used.
Dim iRetVal As Long
Dim sFileExists As String
sFileExists = Dir("c:\acad2000\acad.exe")
If sFileExists <> "" Then
iRetVal = Shell("c:\acad2000\acad.exe" & " /b " & _
"c:\work\scriptwriter.scr", vbMaximizedFocus)
End If
If I make a shortcut to ACAD with the following target:
C:\ACAD2000\acad.exe /b c:\work\SCRIPTWRITER.scr
it executes correctly.
Message 7 of 8
Try this ...
Function LaunchScriptFile(sScriptName as String, WindowStyle as vbwindowstyle
) as boolean
on error goto LaunchScriptFileEH
Dim Dim cmd as string
Dim fso As New scripting.FileSystemObject
If fso.FileExists("C:\Program Files\AutoCAD 2002\ACAD.EXE") = True then
cmd = """C:\Program Files\AutoCAD 2002\ACAD.EXE"" /nologo /b """ & sScriptName & """"
Shell cmd, WindowStyle
LaunchScriptFile = True
else
LaunchScriptFile = False
endif
set fso = nothing
exit function
LaunchScriptFileEH:
exit function
Message 8 of 8
OK, read the attached .txt since the formatting got smashed.
