ARX purge?
ARX purge?
ARX purge?
I posted about an odd message I'm getting in certain drawings from certain
clients. At this point, I'm guessing it has something to do with AEC object
enablers loading routines that interpret lingering data, which is being
carried through.
The one place that I notice it the most at this point is when I try to type
'DS' - shortcut for the DIST command. I can to ARX/Command and in the list
I can see a line - C: C:DS. But I can't determine anything else that
indicates what is happening.
Thoughts?
Ok, this is really driving me nuts! I'm taking a closer look and seeing
that it seems to happen in only certain drawings, and it's happening
everytime I enter ANY command at the command prompt. I keep seeing the
message - ARX_FEHLER: eNotThatKindOfClass - repeated 4 times both before
and after the command.
ARGH!
"Jason Wilder" wrote in message
news:9F127106BF88CB7DDD52279CDD78DD17@in.WebX.maYIadrTaRb...
object
> carried through.
type
list
> Thoughts?
Get the latest object enablers from here:
http://pointa.autodesk.com/local/enu/portal/prodcent/autodesk_obj_enabler.js
p
