Specify layout names for block insertion?
How would I specify the Layout names here?
Public Sub InsertBlocks()
    Dim blockObj1 As AcadBlockReference
    Dim blockObj2 As AcadBlockReference
    Dim blockObj3 As AcadBlockReference
    Dim InsPoint(0 To 2) As Double
    InsPoint(0) = 0#: InsPoint(1) = 0#: InsPoint(2) = 0#
    File1 = "C:\Program Files\Autodesk\AutoCAD 2015\Support\Sheet1.dwg"
    File2 = "C:\Program Files\Autodesk\AutoCAD 2015\Support\Sheet2.dwg"
    File3 = "C:\Program Files\Autodesk\AutoCAD 2015\Support\Sheet3.dwg"
    Set blockObj1 = ThisDrawing.PaperSpace.InsertBlock(InsPoint, File1, 1#, 1#, 1#, 0) 'Layout1
    Set blockObj2 = ThisDrawing.PaperSpace.InsertBlock(InsPoint, File2, 1#, 1#, 1#, 0) 'Layout2
    Set blockObj3 = ThisDrawing.PaperSpace.InsertBlock(InsPoint, File3, 1#, 1#, 1#, 0) 'Layout3
End Sub
The concept: When a number (1,2,3,etc) is selected from a drop-down list
"1" is selected, "blockObj1" is inserted to Layout1
"2" is selected, "blockObj1" & "blockObj2" are inserted to Layout1 & 2 respectively
"3" is selected, "blockObj1" & "blockObj2" & "blockObj3" are inserted to Layout1, 2, & 3  respectively
...etc...
norman.yuan
ThisDrawing.PaperSpace refers to the block of CURRENT layout. To adding entity (in your case, it is inserting block reference) to a layout (layout block, actually), you can
either:
set the target layout as active layout, and then call ThisDrawing.PaperSpace.Add/Insert(...)
such as:
ThisDrawing.ActiveSpace=acPaperSpace
Set ThisDrawing.ActiveLayout=ThisDrawing.Layouts("Layout1")
ThisDrawing.PaperSpace.Insert ....
Set ThisDrawing.ActiveLayout=ThisDrawing.Layouts("Layout2")
Or:
call AcadLayout.Block.Add/Insert(...)
such as:
Dim lay as AcadLayout
Set lay=ThisDrawing.Layouts("Layout1")
lay.Block.Insert ....
Set lay=ThisDrawing.Layouts("Layout2")
Norman Yuan
Drive CAD With Code
Using the "call" method worked perfectly.  Thank you!  Here is what the code looks like now.
        Dim lay1 As AcadLayout
        Dim lay2 As AcadLayout
        Dim lay3 As AcadLayout
            Dim blockObj1 As AcadObject
            Dim blockObj2 As AcadObject
            Dim blockObj3 As AcadObject
            Set lay1 = ThisDrawing.Layouts("Layout1")
            Set lay2 = ThisDrawing.Layouts("Layout2")
            Set lay3 = ThisDrawing.Layouts("Layout3")
    Set blockObj1 = lay1.Block.InsertBlock(InsPoint, File1, 1#, 1#, 1#, 0)
    Set blockObj2 = lay2.Block.InsertBlock(InsPoint, File2, 1#, 1#, 1#, 0)
    Set blockObj3 = lay3.Block.InsertBlock(InsPoint, File3, 1#, 1#, 1#, 0)
End Sub
