Selection Set Rules not working for Layers (VBA)
Private Sub pline_coordinates()
Dim oSset As AcadSelectionSet
Dim oEnt As AcadEntity
Dim fcode(0) As Integer
Dim fData(0) As Variant
Dim dxfcode, dxfdata
Dim setName As String
Dim i As Integer
Dim n As Integer
Dim s As String
fcode(0) = 8                       '0                8
fData(0) = "_SP_Direk"             '"LWPOLYLINE"     "_SP_Direk"
dxfcode = fcode
dxfdata = fData
setName = "$Plines$"
'// make sure the selection set does not exist
For i = 0 To ThisDrawing.SelectionSets.Count - 1
If ThisDrawing.SelectionSets.Item(i).Name = setName Then
'// if this named selection set is already exist then delete it
ThisDrawing.SelectionSets.Item(i).Delete
Exit For
Next i
'// add new selection set with this name
Set oSset = ThisDrawing.SelectionSets.Add(setName)
oSset.Select acSelectionSetAll, , , dxfcode, dxfdata
On Error GoTo Err_Control
'// loop through the all light polylines
ReDim plineAr(0 To oSset.Count - 1, 0 To 4) As Variant
For n = 0 To oSset.Count - 1
Dim cEnt As AcadEntity
Set cEnt = oSset.Item(n)
Dim oPline As AcadLWPolyline
Set oPline = cEnt
Dim coord As Variant
'// get coordinates
coord = oPline.Coordinates
'// collect polyline handles and points into a two-dimensional array
plineAr(n, 0) = oPline.Handle
plineAr(n, 1) = coord(0) ' <--X start point
plineAr(n, 2) = coord(1) ' <--Y start point
plineAr(n, 3) = coord(UBound(coord) - 1) ' <--X end point
plineAr(n, 4) = coord(UBound(coord)) ' <--Y end point
Next n
'// clean up memory
oSset.Delete
'// do what you want with array 'plineAr' here, e.g. write data to the text file etc.
Open "C:\AllPlines.txt" For Output As #1 'Open file for output
For n = 0 To UBound(plineAr, 1)
s = ""
For i = 0 To UBound(plineAr, 2)
s = s & CStr(plineAr(n, i)) & ","
Next i
Write #1, Left(s, Len(s) - 1) 'Write comma-delimited data (cut the last comma from string)
Next n
Close #1 'Close file
Err_Control:
MsgBox Err.Description
End Sub
Hi there,
i found a code that exports all polyline coordinates to txt file.
but when i'm  trying to select a layer and export just that layer, i get an error "Type Mismatch".
it works when
fcode(0) = 0
fData(0) = "LWPOLYLINE"
norman.yuan
Well, you did not explicitly say, but my guess is that you want to select polylines on given layer, not all polylines regardless layers. So, since you only have selection filter on layer "_SP_Direk", everything on that layer is selected. If there is anything on that layer is not AcadLWPolyline, this line of code would give you "type mismatch" error:
    Set oPline = cEnt
Next
You should
Either include entity type filter for the selection:
Dim fcode(0 to 1) As Integer
Dim fData(0 to 1) As Variant
fCode(0)=0:fCode(1)=8
fData(0)="LWPOLYLINE":fData(1)="_SP_Direk"
dxfCode=fCode
dxfData=fData
Or add code to test if an entity in the selectionset is AcadLWPolyline:
If TypeOf cEnt Is AcadLWPolyline Then Dim oPline As AcadLWPolyline set oPline=cEnt
Next
HTH
Norman Yuan
Drive CAD With Code
