Spaces in filename
Spaces in filename
dbrblg
Message 1 of 9
Spaces in filename
dbrblg
I'm trying to print with the following code:
With ThisDrawing
    sTxt = Replace("sTxt is Z:\A\B\Design\2017 Projects\Test Stage\2.dsd", "\", "/")
    .SetVariable "FILEDIA", 0
    .Regen acActiveViewport
    .SendCommand "(command " & Chr(34) & "-PUBLISH" & Chr(34) & " " & Chr(34) & sTxt & Chr(34) & ")" & vbCr
End With
but I am getting the following error in the text window:
Could not locate sheet list file.
Enter name of sheet list <>: nil
I believe it has something to do with the spaces in the filename because if I change to this:
With ThisDrawing
    sTxt = Replace("sTxt is C:\2.dsd", "\", "/")
End With
everything works fine, so I know the DSD file is ok (not that the error indicates it is a problem with the DSD file anyway!!)
What can I do to fix,or prove, this issue?
Replies (8)
Message 2 of 9
try with double quotes (non tested):
sTxt = Replace("sTxt is ""sTxt is Z:\A\B\Design\2017 Projects\Test Stage\2.dsd""", "\", "/")
Message 3 of 9
dbrblg
Sorry, copy / paste error on my part.
Code should read:
With ThisDrawing
    sTxt = Replace("Z:\A\B\Design\2017 Projects\Test Stage\2.dsd", "\", "/")
End With
Unfortunately the editor does not let me put in double quotes so this does not work. Smiley Mad
Message 4 of 9
Ed__Jobe
Try using the backslash escape character. \" Doing that, you also shouldn't need the replace function. The lisp interpreter at the command line won't see the backslashes in the quoted path name as escape characters.
sTxt = "\"Z:\A\B\Design\2017 Projects\Test Stage\2.dsd\""
Ed
How to post your code.
Message 5 of 9
norman.yuan
This is VBA code, where you cannot use \" to escape for literal double-quote in string. It should be double the double-quote, as RICVBA suggested.
Norman Yuan
Drive CAD With Code
Message 6 of 9
norman.yuan
You do write code in AutoCAD VBA editor, don't you? The VBA Editor does accept doubled double-quote as literal double quote in a string value. Try it again, and make sure your typing is correct.
Norman Yuan
Drive CAD With Code
Message 7 of 9
dbrblg
Appears that double quotes is still not accepted by AutoCAD....
This is the latest code (tidied up):
Private Function Test_Function()
    Dim s As String
    s = "C:\dsd\spaces in\file name\2.dsd"
    Call PublishProject(s)
End Function
Private Function PublishProject(strDSDFileName As String)
    Dim strDSDCommandFileName As String
    Dim fso As New Scripting.FileSystemObject
    If (fso.FileExists(strDSDFileName)) Then
        With ThisDrawing
            strDSDCommandFileName = Replace(strDSDFileName, "\", "/")
            .SendCommand "(command " & Chr(34) & "-PUBLISH" & Chr(34) & " " & String(2, 34) & strDSDCommandFileName & String(2, 34) & ")" & vbCr
            .SetVariable "FILEDIA", 1
        End With
        If (bDeleteDSDFile) Then
            On Error GoTo err
            Call fso.DeleteFile(strDSDFileName)
            On Error GoTo 0
        End If
    End If
    Exit Function
err:
    If (err.Number = 70) Then
        Call MsgBox("Failed to delete DSD File due to permissions", vbCritical, "Warning")
    End If
        err.Clear
        Resume Next
End Function
and this is what is shown on the command line.....
It does not seem to be able to find the DSD file.  I've seen many posts which say that double quotes are required but for some reason this fails Smiley Surprised
Message 8 of 9
to obtain the result of double quote use:
strDSDCommandFileName = Replace("""" & strDSDFileName & """", "\", "/")
then you have to get rid of those:
String(2, 34)
Message 9 of 9
dbrblg
Thanks for the suggestion, unfortunately it still does not work....
        With ThisDrawing
            .SendCommand "(command " & Chr(34) & "-PUBLISH" & Chr(34) & " " & strDSDCommandFileName & ")" & vbCr
        End With
I do however get a slightly different error:
So with a little adjustment to get the double quotes in the way you suggested:
        With ThisDrawing
            strDSDCommandFileName = Replace("""""" & strDSDFileName & """""", "\", "/")
        End With
gave me this error:
I did get the double quotes, but a different error too...
