Shuffeling application windows
Message 1 of 8
I am writing a procedure in AutoCAD that uses Excel. I am using the excel
file open dialog to opening an Excel file. When I use the GetOpenFilename to
select the file I had to get the Excel application on top and used
"apExcel.Application.Visible = True" where apExcel is my excel application
object. Now when I have Then when I have finished working in Excel, control
reverts back to AutoCAD. Any subsequent dialogs or forms are not visible as
they are hidden behind the Excel application window. I tried setting
"ThisDrawing.Application.Visible = True" but this did not put the AutoCAD
application object on top. I am a bit reluctant to set
"apExcel.Application.Visible = False" as if I crash out of my routine Excel
will be invisible. Is there a way to put various applications on "top"?
I will be having this problem a lot as I will be jumping between AutoCAD and
Excel a lot as my form where I set the ranges is in AutoCAD and my data is
in Excel.
Any assistance will be appreciated.
Regards
Sean
Replies (7)
Message 2 of 8
Ed__Jobe
How about the AppActivate statement?
Ed
How to post your code.
Message 3 of 8
try this:
(excel or autocad app).Parent.Windows(1).Visible = True
I'm not sure if it will work, I've battled the same thing you are now
though. My app leaves Excel on top last, as that is where the finished work
is being done. Another suggestion is to put a msgbox up on screen (say
something like 'Done'), this should bring back autocad.
PS: I'd like to hear if you are able to fix it with either one of these...
Kevin
"Sean Bartleet" wrote in message
news:A383CA64CEE15334E3B579ABA37D3DC2@in.WebX.maYIadrTaRb...
> Hi,
to
control
as
Excel
and
> in Excel.
> Regards
> Sean
Message 4 of 8
I had hoped the following would work. It finds the hWnd of the Autocad
window by its caption, and then uses the API to bring the window to top.
When I run it from the IDE, however, with AutoCAD behind other programs,
Autocad pops *almost* to the top, just behind the IDE.
warning: with API development I've always heard that you should save your
work often, in case it locks up your machine.
warning2: I'm not sure what this code would do if the Autocad window were
minimized when the code gets to BringToTop...
Hope this helps
with help from:
http://groups.google.com/groups?q=BringWindowToTop+group:microsoft.public.vb
.winapi.*&hl=en&lr=&ie=UTF-8&oe=UTF-8&selm=e%24Z29fWFBHA.1940%40tkmsftngp04&
rnum=6
Option Explicit
Private Declare Function BringWindowToTop Lib "USER32" (ByVal hwnd As Long)
As Long
Private Declare Function FindWindow Lib "USER32" Alias "FindWindowA" ( _
ByVal lpszClassName As String, ByVal lpszWindow As String) As Long
Sub test_window_top()
Dim hwnd As Long
hwnd = FindWindow(vbNullString, ThisDrawing.Application.Caption)
BringWindowToTop hwnd
End Sub
Message 5 of 8
1. When running the code without the ide visible (i.e.. normal users), that
shouldn't be a problem
2. You could set xlApp.WindowState = xlNormal to make it normal first, that
would eliminate that problem (where xlApp would be Autocad.application in
this case)
Kevin
"James Belshan" wrote in message
news:261B31CD81AF844B6175689F6565C7B9@in.WebX.maYIadrTaRb...
> Hope this helps
> with help from:
> rnum=6
> Option Explicit
Long)
> As Long
> Dim hwnd As Long
> End Sub
Message 6 of 8
Thanks but this is an event not a statement. Unless I am missing something.
See my other post below for the solution I found.
Thanks for the help.
Sean
"Ed_Jobe" wrote in message news:f12d41b.0@WebX.maYIadrTaRb...
Message 7 of 8
Thanks, Unfortunately I could not get this to work, I am not sure what
happened but AutoCAD did not get back to the top. Unless I am missing
something.
FYI, I found the code below on the Excel VBA NG.
Sean.
Posted previously by Jim Rech:
http://groups.google.com/groups?q=journal+group:microsoft.public.excel.progr
amming+author:Rech&hl=en&lr=&ie=UTF-8&oe=UTF-8&safe=off&selm=OgCCVl4vBHA.159
2%40tkmsftngp07&rnum=1
References:
Subject: Re: Switch Back to Excel
Date: Wed, 27 Feb 2002 07:22:21 -0500
Message-ID:
Newsgroups: microsoft.public.excel.programming
NNTP-Posting-Host: p0016c72ea.us.kpmg.com 199.207.253.96
Windows doesn't approve of inactive applications switching the focus back to
themselves.
Try this:
Public Declare Function GetWindowThreadProcessId Lib _
"user32" (ByVal hWnd As Long, lpdwProcessId As Long) As Long
Public Declare Function AttachThreadInput Lib "user32" _
(ByVal idAttach As Long, ByVal idAttachTo As Long, _
ByVal fAttach As Long) As Long
Public Declare Function GetForegroundWindow Lib "user32" () As Long
Public Declare Function SetForegroundWindow Lib "user32" _
(ByVal hWnd As Long) As Long
Public Declare Function IsIconic Lib "user32" _
Public Declare Function ShowWindow Lib "user32" _
(ByVal hWnd As Long, ByVal nCmdShow As Long) As Long
Declare Function FindWindowA Lib "user32" (ByVal lpClassName _
As Long, ByVal lpWindowName As String) As Long
Const SW_SHOW = 5
Const SW_RESTORE = 9
''Run this an then switch to another application.
Sub Test()
Application.OnTime Now + TimeValue("00:00:05"), "BringTotop"
End Sub
Sub BringToTop()
ForceForegroundWindow FindWindowA(0, Application.Caption)
End Sub
''All this is necessary in Windows 98/NT5 because MS disabled
'' SetForegroundWindow unless
'' the caller is itself the foreground window.
'' From Visual Basic Programmers Journal Feb 1999 pg 94
Function ForceForegroundWindow(ByVal hWnd As Long) As Boolean
Dim ThreadID1 As Long
Dim ThreadID2 As Long
Dim nRet As Long
If hWnd = GetForegroundWindow Then
ForceForegroundWindow = True
Else
ThreadID1 = GetWindowThreadProcessId( _
GetForegroundWindow, ByVal 0&)
ThreadID2 = GetWindowThreadProcessId(hWnd, ByVal 0&)
If ThreadID1 <> ThreadID2 Then
AttachThreadInput ThreadID1, ThreadID2, True
nRet = SetForegroundWindow(hWnd)
AttachThreadInput ThreadID1, ThreadID2, False
Else
End If
If IsIconic(hWnd) Then
ShowWindow hWnd, SW_RESTORE
Else
ShowWindow hWnd, SW_SHOW
End If
ForceForegroundWindow = CBool(nRet)
End If
End Function
Jim Rech
Excel MVP
Message 8 of 8
Ed__Jobe
AppActivate is a statement of the form AppAcivate title [wait]. Pass it the title of the desired app to activate (bring to front).
Ed
