Set Paper Size to Layout
rmcefr
rmcefr
Hi
following Code get error of "CanonicalMediaName "
My_Layout.ConfigName = "DWG To PDF.pc3"
My_Layout.CanonicalMediaName = "ISO_A1_(594.00_x_841.00_MM)"
I try this also
My_Layout.CanonicalMediaName = "ISO A1 (594.00 x 841.00 MM)"
May there is an special formula of paper sizes names?
thanks
thanks
Ed__Jobe
Try this:
In a test dwg, set the current page setup to the paper size you want then run the following code:
Sub FindCname ()
   Debug.Print ThisDrawing.ActiveLayout.CanonicalMediaName
End Sub
Then in the Immediate window, copy the printed result to your sub.
There is also the GetCanonicalMediaNames method.
Ed
How to post your code.
