Sending arguments to macro from AutoLISP
I saw a description of how you can send arguments to a vba macro from
AutoLISP, not directly, but a workaround, sort of. Now I can't find it
again. Anyone got an example of how to use
(command "_vbarun" "macro" "arg1" "arg2")
and what the VBA code is needed?
Monte
Youre probably referring to the thread titled:
Options when calling a function from a button within acad?
Monte wrote in message
news:3ad76efb.10310716@discussion.autodesk.com...
> Thanks,
> Monte
Try to use the GetString function.:
Sub RenameBlocks()
' This routine converts blocknames to be preceeded with the filename.
On Local Error Resume Next
Dim BlockDef As AcadBlock
FromTxt$ = ThisDrawing.Utility.GetString(False, "Find what ")
If FromTxt$ = "" Then
ThisDrawing.Utility.Prompt "Cancelled"
Exit Sub
End If
ToTxt$ = ThisDrawing.Utility.GetString(False, "Replace with ")
Kind regards
Michael Christoffersen
3DI
"Monte" wrote in message
> Thanks,
> Monte
