list blocks
list blocks
Message 1 of 8
list blocks
Hi, I would like to cycle through all of the blocks in a drawing
and then check to see which ones have attributes.
how do I go about this
thanks in advance
MICK
Replies (7)
Message 2 of 8
Dim blkDef As AcadBlock
For Each blkDef In ThisDrawing.Blocks
If blkDef.HasAttributes Then
Next
Fair warning: it's possible for GetAttributes to return zip even when
HasAttributes returns True. This is because of a difference in their
implementations: HasAttributes considers all attributes in a block, even
constant attributes. GetAttributes, on the other hand, only works with
editable attributes.
http://www.acadx.com
Win an autographed copy of
"Mastering AutoCAD 2000 Objects"
by Dietmar Rudolph
"mick_and_rosie" wrote in message
news:4B418767D69F7199391D9E625BF0F828@in.WebX.maYIadrTaRb...
> thanks in advance
> MICK
Message 3 of 8
Actually, I gave you a bum steer. The GetAttributes method is in the
AcadBlockReference class, not AcadBlock. Use the block's Items collection
and check each object using the TypeOf operator:
Dim blkDef As AcadBlock, subEnt As AcadEntity
For Each subEnt In blkDef
If TypeOf subEnt Is AcadAttributeDefinition Then
Next
Next
by Dietmar Rudolph
Message 4 of 8
Hi Frank, I tried your code and I get the following error message
"Compile error
user defined type not defined"
and the following code is highlighted "TypeOf subEnt Is
AcadAttributeDefinition"
what am I doing wrong
PS I am using R2000
MICK
Frank Oquendo wrote in message
news:1C0B04A224EAE6F081DBDE0D68581BC4@in.WebX.maYIadrTaRb...
> End If
> Next
> Next
> by Dietmar Rudolph
Message 5 of 8
That would be bum steer #2. The Object Browser says the correct type is
AcadAttribute, not AcadAttributeDefinition.
by Dietmar Rudolph
news:C4B0B6971D50D41750964997108E4BA1@in.WebX.maYIadrTaRb...
> "Compile error
> PS I am using R2000
> MICK
Message 6 of 8
thanks Frank that works fine. one more question if I may
once I have found a block with attributes I want to check for a particular
tag
how do I do that.
thanks again
MICK
news:04A7920BBFD72F2F207C83FD7339ED80@in.WebX.maYIadrTaRb...
> by Dietmar Rudolph
> > "Compile error
> > PS I am using R2000
> > MICK
Message 7 of 8
If TypeOf subEnt Is AcadAttribute Then
If subEnt.TagString = Then
Next
Next
by Dietmar Rudolph
news:C50BFF8DA86322FAA3F2B577BFA2FDBF@in.WebX.maYIadrTaRb...
> tag
> how do I do that.
> thanks again
> MICK
Message 8 of 8
thanks again Frank that works great
MICK
