Select named View to display in paper space viewport
Hello all,
I have created a named View in model Space that I would like to set as current in a paper space viewport (PViewport object in AutoCAD VBA). The thing is I'm clueless as to how I can achieve this. I've unsuccessfully searched the internet for a solution for days. Note: I don't want to use SendCommand.
maratovich
Use this:
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
That software of yours is really cool, but I'm after the solution to implement it myself in my own program. Guidance would suffice. Thank you.
Ed__Jobe
The first part of the video showed how you can just use the view command. "-VIEW Restore ViewName". The second part showed his software. However, since 2018.1 there is a new option of the MVIEW command that places a viewport using a named view or creates a new view to use. See the context-sensitive Layout ribbon.
Ed
How to post your code.
Thanks for your reply. I was aware of the -View + Restore command but I have to stay away from SendCommand because my code continues after the selection of the view and it might cause trouble, right? I was once told that SendCommand had only to be used at the very end of the code.
Isn't possible to set the view through code in the PViewport then?
Thanks for your video and the MView command 🙂
