Rotate addtext in VBA
Dear all,
I am new to this and actually have only a small question:
I have written some code to quickly generate circles with text on top.
CODE:
Private Sub CommandButton3_Click()
pi = 3.14159265358979
UserForm3.Hide
pt1 = ThisDrawing.Utility.GetPoint(, "Pick lower left corner:")
If (ComboBox27.Text) = "DN50" And (ComboBox14.Text) = "NO" Then
pt2 = ThisDrawing.Utility.PolarPoint(pt1, 0, Val(125))
pt3 = ThisDrawing.Utility.PolarPoint(pt2, pi / 2, Val(25))
pt5 = ThisDrawing.Utility.PolarPoint(pt1, 0, Val(250))
pt6 = ThisDrawing.Utility.PolarPoint(pt2, pi / 2, Val(70))
pt7 = ThisDrawing.Utility.PolarPoint(pt6, pi / 2, 0)
ThisDrawing.ModelSpace.AddLine pt1, pt5
ThisDrawing.ModelSpace.AddCircle pt3, Val(25)
ThisDrawing.ModelSpace.AddText "DN50", pt7, 50
Else
End If
My question is how do i rotate the DN50 text already in my VBA code?
And also how do unbold the "DN50" text?
Ed__Jobe
Save the results of the Addxxx method to a variable. Then you have something with which to change properties.
Dim oText as AcadText
oText = ThisDrawing.ModelSpace.AddText "DN50", pt7, 50
oText.Rotation = 90
Ed
How to post your code.
