Repost: GetLinks problem in Event function
wesbird
wesbird
Hi:
I have a function to check if any one change(delete, modify) the pline with link value, I will create a flag in the drawing (dictionary).
Now I have a "Run-time error '-2147467259(80004005) Unspecified error" error at
Set Links = DbConnect.GetLinks(, objIds, CAO.kEntityLinkType)
Does this mean GetLinks does not work with the object within a ObjectModified Event? How should I make this work?
Thank you a lot and I really appreaciate your help.
Wes
Here is my code:
Private Sub AcadDocument_ObjectErased(ByVal ObjectID As Long)
AutoCADDatabaseChangedEvent ObjectID
End Sub
Public Function AutoCADDatabaseChangedEvent(ByVal ObjectID As Long)
If IsRealSuiteRunning Then GoTo Final
' check if link object
Dim colTmp As Collection
Set colTmp = GetKeyValue3(ObjectID)
If colTmp.Count > 0 Then
If ReadProfile2(dictProfileName, dictDBKey) = 1 Then
IsRealSuiteRunning = True
WriteProfile2 dictProfileName, dictDBKey, 2
Final:
End Function
Function GetKeyValue3(ByVal ObjID As Long) As Collection
Dim Ret As New Collection
' Init dbConnect
Set DbConnect = GetInterfaceObject("CAO.DbConnect.16")
Dim objIds(0 To 0) As Long
objIds(0) = ObjID
Dim Links As CAO.Links
' Debug
If DDebug < 5 Then MsgBox "Links.Count: " & Links.Count & vbCrLf & _
ObjID & "-" & Links.Item(0).ObjectID, , "Debug"
If Links Is Nothing Then GoTo Final
Dim link As CAO.link
Dim Kvs As CAO.KeyValues
Dim kv As CAO.KeyValue
Dim kvEL As kvCol
For Each link In Links
Set Kvs = link.KeyValues
' iterate each KeyValue
' debug
If DDebug < 20 Then
For Each kv In Kvs
MsgBox "Name:" & kv.FieldName & " Value:" & kv.Value, , "Debug"
Next kv
Set kvEL = New kvCol
kvEL.KeyValue = Kvs(0).Value
Ret.Add kvEL
Next link
Final:
Set Links = Nothing
Set GetKeyValue3 = Ret
End Function
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
Your code looks fine, the problem may be that you are trying to reference an object that has been deleted. Try calling your function and passing a known ObjectID for an object that still existing in the DWG and see if you get the error.
Scott
