Repost: GetLinks problem in Event function
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi:
I have a function to check if any one change(delete, modify) the pline with link value, I will create a flag in the drawing (dictionary).
Now I have a "Run-time error '-2147467259(80004005) Unspecified error" error at
Set Links = DbConnect.GetLinks(, objIds, CAO.kEntityLinkType)
Does this mean GetLinks does not work with the object within a ObjectModified Event? How should I make this work?
Thank you a lot and I really appreaciate your help.
Wes
Here is my code:
Private Sub AcadDocument_ObjectErased(ByVal ObjectID As Long)
AutoCADDatabaseChangedEvent ObjectID
End Sub
Public Function AutoCADDatabaseChangedEvent(ByVal ObjectID As Long)
If IsRealSuiteRunning Then GoTo Final
' check if link object
Dim colTmp As Collection
Set colTmp = GetKeyValue3(ObjectID)
If colTmp.Count > 0 Then
If ReadProfile2(dictProfileName, dictDBKey) = 1 Then
IsRealSuiteRunning = True
WriteProfile2 dictProfileName, dictDBKey, 2
End If
End If
Final:
End Function
Function GetKeyValue3(ByVal ObjID As Long) As Collection
Dim Ret As New Collection
' Init dbConnect
Set DbConnect = GetInterfaceObject("CAO.DbConnect.16")
Dim objIds(0 To 0) As Long
objIds(0) = ObjID
Dim Links As CAO.Links
' Debug
If DDebug < 5 Then MsgBox "Links.Count: " & Links.Count & vbCrLf & _
ObjID & "-" & Links.Item(0).ObjectID, , "Debug"
If Links Is Nothing Then GoTo Final
Dim link As CAO.link
Dim Kvs As CAO.KeyValues
Dim kv As CAO.KeyValue
Dim kvEL As kvCol
For Each link In Links
Set Kvs = link.KeyValues
' iterate each KeyValue
' debug
If DDebug < 20 Then
For Each kv In Kvs
MsgBox "Name:" & kv.FieldName & " Value:" & kv.Value, , "Debug"
Next kv
End If
Set kvEL = New kvCol
kvEL.KeyValue = Kvs(0).Value
Ret.Add kvEL
Next link
Final:
Set Links = Nothing
Set GetKeyValue3 = Ret
End Function
Wes
Here is my code:
End Sub
End If
End If
Final:
End Function
' Init dbConnect
objIds(0) = ObjID
' Debug
Dim kvEL As kvCol
' debug
If DDebug < 20 Then
For Each kv In Kvs
Next kv
End If
Ret.Add kvEL
Next link
Final:
Set Links = Nothing
End Function
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
