Why does it come to an error when load the application using VLAX.cls
When I run my sub in AutoCAD 2004, the following codes will come to an error: Private Sub Class_Initialize() If Left(ThisDrawing.Application.Version, 2) = "15" Then Set VL = ThisDrawing.Application.GetInterfaceObject("VL.Application.1") ElseIf Left(ThisDrawing.Application.Version, 2) = "16" Then Set VL = ThisDrawing.Application.GetInterfaceObject("VL.Application.16") ' error occurs End If Set VLF = VL.ActiveDocument.Functions End Sub Thanks!
Enter this "(vl-load-com)" at the command line and then see if you still get the error.
Regards - Nathan
